2.0 issue
Old May 8, 2007 | 07:46 PM
red06s/c's Avatar
2.0 issue
hey peepz i have a 06 ss/sc with 15,000miles... from the day i bought the car it has never went over 180 degrees no matter what the temp is outside. im always and watching my coolant readings and seen its been going up to like 210-215 under normal driving. if i let the car idle it will hit 230 within 2 minutes no joke.The fans are kicking on at like 230. ive watched the boost and its not going over 10psi, and its running a little rough. So any ideas what it could be or should i dealer it or and i just worring to much??
Psykostevo's Avatar
DEALER!
Old May 8, 2007 | 07:49 PM
distillion's Avatar
https://www.cobaltss.net/forums//showthread.php?t=58120
maybe..
Old May 8, 2007 | 07:52 PM
red06s/c's Avatar
Originally Posted by distillion
but the only thing i have on my car is a intake which has been on forever and my ingalls which has been on for 5-6 months, everything else is stock
Old May 8, 2007 | 07:53 PM
CJ BadBlackSS's Avatar
This is one of those "you should bring it to the dealer ASAP" moments. Theres nothing we can easily help you with. Its probably something with the coolant system so it should be nicely warrantied.
Old May 8, 2007 | 09:12 PM
red06s/c's Avatar
Ok thanks... thats just what i was wondering.
o yea i forgot that if im going to take my intake and all that off im going to have them fix the spitting and sputtering threw 1st and second gear in the morning
Old May 9, 2007 | 08:43 AM
kenhebe's Avatar
There is nothing to worry about. THe fans do not come on our vehicles until it hits about 225-230. Under normal driving conditions, it is about 180-185, but when it is idling it will skyrocket becuase there is no airflow to the radiator. Your boost is suffering because it is so hot. The hotter it is, the less boost you have.
Old May 9, 2007 | 08:46 AM
D4u2s0t's Avatar
anything under 230 is considered "normal". when it went to 215 or so was it in stop and go traffic? because that's very normal. if it hits 230, once you start driving it should go down after a while. these engines run hot, there's most likely nothing to worry about. but like said you can take it to the dealer, but they'll tell you it's normal
Old May 9, 2007 | 02:52 PM
red06s/c's Avatar
i called the dealer and they said drive it..and if somethings wrong drive it until it breaks...looks good to say that
Old May 14, 2007 | 12:14 PM
NO. 27 SS's Avatar
if you want to drop the temp you can always drain the antifreeze out and replace with jsut water and water wetter. This will drop your collant temps like 15-25deg but make sure you replace the water with dex-cool b4 winter... the dex-cool (antifreeze) is only there so the water doesn't freeze but sucks as a coolant...
Old May 23, 2007 | 11:32 AM
sauced1173's Avatar
yeah the dexcool is also there as a lubricant and anti-corrosion agent. you will have to get other additives if you just want to use plain water. such as coolant system lubricant and anti-corrosion agents.
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 28, 2015 12:51 PM
