2.7 and a P0300 CODE
Old Apr 7, 2007 | 07:55 PM
CobaltBob's Avatar
installed a 2.7 setup at the Fredrick meet today, drove all the way home fine. turned the car off, then back on like 10 min later to go get food and 5 min into my drive i threw a P0300 code..Random Multiple Misfire..WHAT SHOULD I DO..Please help..Thankx
Old Apr 7, 2007 | 07:57 PM
CTORANGESC's Avatar
How do your spark plugs look, are they gapped right?
Old Apr 7, 2007 | 08:08 PM
CobaltBob's Avatar
i didnt really have a big hand in the install..lol.. i can always check them in the mornin, what should they be gapped at?
Old Apr 7, 2007 | 08:12 PM
CTORANGESC's Avatar
Should be gapped to .035"
Old Apr 7, 2007 | 08:19 PM
CobaltBob's Avatar
ok thanks alot, any thing else i should check while im under the hood?
Old Apr 7, 2007 | 08:20 PM
CTORANGESC's Avatar
Well if you didnt have a tune to go along with the 2.7, then that may be your problem
CobaltBurst's Avatar
just plugs imo
Old Apr 7, 2007 | 08:26 PM
CobaltBob's Avatar
NO WAY.. i got tuned by the world famous DOC..lol..so im sure there is nothin wrong there
Old Apr 7, 2007 | 08:28 PM
CTORANGESC's Avatar
Ok just making sure
Old Apr 7, 2007 | 08:36 PM
CobaltBob's Avatar
Ok just making sure
ok..lol..ill check them in the am..i really hope thats all it is
Old Apr 7, 2007 | 10:50 PM
rickyw's Avatar
make sur e on the plugs
Old Apr 8, 2007 | 09:05 AM
Doc's Avatar
Doc
they wouldn't clear it for him....the plugs are suspect. If that doesn't solve it then I will come back up there and work on it some more.
Old Apr 8, 2007 | 09:17 AM
CobaltBob's Avatar
ok thanks..im goin to check them now
do i need to disconect the negative on the battery before i check them, will i loose my tune if i do
Old Apr 8, 2007 | 09:27 AM
Doc's Avatar
Doc
no need to disconnect anything.
the tune won't go anywhere....its like herpes, there to stay
Old Apr 8, 2007 | 10:15 AM
CobaltBob's Avatar
regaped and cleaned and the light stays on.. will it go off after the prob is fixed or does it need to be cleared
Old Apr 8, 2007 | 10:23 AM
CTORANGESC's Avatar
How is the car running?
Old Apr 8, 2007 | 10:26 AM
CobaltBob's Avatar
ok..although at idle the rpms dont stay constant..jump from like 790 to 810
but it did that before the light, i disconected the negative for a while to see if the code goes away
poppagun's Avatar
it has to go through 3 cycles before its is cleared so leve it be for a little.
Old Apr 8, 2007 | 10:27 AM
CobaltBob's Avatar
how long is that
Old Apr 8, 2007 | 10:29 AM
Sunburst girl's Avatar
if the misfires are at idle, check for vacuume leaks perhaps at the intake piping after the MAF sensor, or anywhere after the MAF sensor actually....injector o-rings....vacuume lines....etc..
Old Apr 8, 2007 | 11:56 AM
CobaltBob's Avatar
I disconected the batery and the light is gone SO FAR..cant find ZEX plugs anywhere
Old Apr 8, 2007 | 12:13 PM
2006ArrivalBlueSS's Avatar
Same thing happened to me right after my install and tune. Luckily I have the Aeroforce so I cleared the code. My tuner, Mase, said it was because of the 91 octane I had in there. Filled it up with 94 and I haven;t had the light come on since. What octane level is your tune for?
Old Apr 8, 2007 | 12:30 PM
CobaltBob's Avatar
i dunno, it was DOC tuned, i run 93 though
turbochargedss2012
Sep 20, 2023 12:17 PM
Builttss
Oct 4, 2015 10:21 AM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
