2006 SC. What does this sensor connect to?
Old Jun 29, 2018 | 07:11 PM
zakmllr's Avatar
This sits just below in fuel rail on the same bracket that hold the coolant line on the intake side of my supercharger. I was installing my fuel pressure regulator when I realized it wasn’t plugged into anything. It looks as if a hose connect to it, but I do not see any loose hoses.
Old Jun 29, 2018 | 07:18 PM
user 72239's Avatar
thats your TMAP sensor. it should plug into the intake manifold somewhere.
Old Jun 29, 2018 | 07:23 PM
zakmllr's Avatar
It bolts on a bracket that is not connected to the intake manifold. Does it connect by hose?
Old Jun 30, 2018 | 12:08 AM
Sharkey's Avatar
no it isnt and should not be.
this sensor is your BARO, or barometric pressure sensor. it is bolted to the bracket and doesnt connect to anything other than the wiring. its function is to detect the barometric pressure so the ecm can make corrections for altitude changes.
Old Jun 30, 2018 | 01:28 AM
user 72239's Avatar
^ right i was incorrect. I remember seeing it on one side of the intake mani in a bracket.
Old Jun 30, 2018 | 11:32 AM
zakmllr's Avatar
Thank you, I was worried I unplugged something with an install at some point and never put it back. Now I can rest easy.
juice3
Dec 2, 2012 02:21 PM
advise
Dec 30, 2009 03:41 PM
RednBlack
Apr 21, 2009 08:57 PM
ItalianJoe1
Sep 7, 2008 10:22 AM
memphisr24
Jun 11, 2008 10:27 PM
