2006, SS, 2.4, oil leak above starter below intake
Old 12-11-2017, 05:01 PM
oclaf's Avatar
Cool 2006, SS, 2.4, oil leak above starter below intake
anyone have this issue? it leaks oil in that spot, cant see even up in air, unless i take things off like, starter, intake, and lord knows what else...any ideas before i tear into it? i ask as i read on here how to remove inner door panel when door wouldnt open and i had success...thanks
Mark
Old 12-11-2017, 05:26 PM
there is RTV sealant used on two halves of the block in the spot you are describing. Never heard of one leaking there though. How many miles?
Old 12-11-2017, 07:05 PM
Henry3959's Avatar
You have 2 places where it can be leaking there.
Oil Pressure switch. Most likely!
Crank Sensor.
I have my engine apart so their easy to get to from above but you would be better off pulling the starter.
If you wanted to put some black light engine oil dye in it and run it a while, it should show up quickly.
oclaf (12-11-2017)
Old 12-28-2017, 03:09 PM
oclaf's Avatar
gonna try it this weekend, pull the starter and see what i have...betting on oil pressure switch...
Diaz1488
02-10-2014 04:30 PM
ronn
10-30-2011 04:40 PM
wordsthatiwrote
08-29-2007 02:53 AM
Salth2o
04-02-2006 11:10 PM
Mike Richmond
03-16-2006 12:59 PM
Quick Reply: 2006, SS, 2.4, oil leak above starter below intake
