2007 Supercharged Overheating
Old Dec 22, 2008 | 11:56 AM
samijo0703's Avatar
very true thanks!! i'll look today.. anything else to be looking for? i know damage of course.. but any other ideas of what it could be
Old Dec 22, 2008 | 12:50 PM
25bduse's Avatar
This is perfectly normal for the cobalt when sitting still. I have seen my coolant temp. get up in the 220's before at idle. Like someone mentioned, no movement no cooling.
Old Dec 22, 2008 | 01:23 PM
artawesome's Avatar
normally when my fan kicks in the temp goes down right away.
does your temp gauge ever come on?
Old Dec 22, 2008 | 01:25 PM
25bduse's Avatar
My temp. also shoots down when the fans kick on
Old Dec 22, 2008 | 08:34 PM
Rodimus_Prime's Avatar
ive never had stock cooling fan settings, i hp tuned mine the night I got it, but I can tell you that its never been above 215 even in 90 degree heat idling for a half hour
potential water pump issue?
Old Dec 22, 2008 | 08:37 PM
distillion's Avatar
heres my shitty t-stat.
engine wouldn't warm up lol...
Old Dec 22, 2008 | 10:30 PM
samijo0703's Avatar
nope never comes on.. the first time i noticed it i was just running thro to see the oil life.. and happened to see a high number, called a friend and had him look up the temp for "overheating" on my car and he said anything over 210.
Old Dec 22, 2008 | 10:32 PM
D4u2s0t's Avatar
your friend is wrong... 210 is well withing what's considered normal operating temperature.
Old Dec 22, 2008 | 10:36 PM
samijo0703's Avatar
well i'm sure 240 isn't.. and thats what i'm worried about..
Old Dec 23, 2008 | 12:59 AM
D4u2s0t's Avatar
as long as it goes back down after you start driving it's not anything to worry about. if it stays at 240 for a long time, then that's a problem. but it should go down once you start moving.
Old Dec 23, 2008 | 01:10 AM
  #36
JimzSS's Avatar
do the fan[s] come on at all ?
let it idle, heater controls off and check them.
Old Dec 23, 2008 | 01:14 AM
  #37
berto's Avatar
Damn My Old Lsj Never Got Hotter Than 185 Dude
Old Dec 23, 2008 | 01:46 AM
  #38
mtbrent's Avatar
I constantly watch my coolant temps on the dic. Since the cold weather has arrived, whenever the heat is on, especially full blast, the coolant temps will rise faster than when no heater was on. At stop lights it will jump from 190 up to 200-205 within 20-30seconds. If I pull up to the light and turn the heat completely off, it takes MUCH longer to heat up the coolant temps to the same range. If I let it creep up above 200 and turn off the heat and quickly turn to cold air, not ac, temps will drop a few degrees and usually hold steady til I get moving again when they drop quickly. Not sure if anyone else has seen this, but just my experience. This is on a 2.4sc btw.
Old Dec 23, 2008 | 02:05 AM
  #39
SaturnRL's Avatar
^^^ That sounds ass backwards to me. The heater pulls heat off the engine.
Old Dec 23, 2008 | 10:03 AM
  #40
rnjmur's Avatar
Originally Posted by rnjmur
The PCM commands Low Speed Fans ON under the following conditions:
• Engine coolant temperature (ECT) exceeds approximately 106°C (223°F).
• A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
• After the vehicle is shut off, the ECT at key-off is greater than 140°C (284°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The PCM commands High Speed Fans ON under the following conditions:
• ECT reaches 110°C (230°F).
• A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
• When certain DTCs set
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10 mph. This is to prevent a fan from cycling ON and OFF excessively at idle.
As you can see from this post earlier in the thread; it is perfectly normal to see tempuratures around 230 while sitting in traffic. The fans don't kick on to high speed until 230. If you are seeing 240 I might be a little concerned. If it is getting to 240 pretty fast then there maybe something going on. You should have to be in stop and go traffic for quite a few minutes before the tempurature climbs to 230 especially in cooler weather.
Old Dec 23, 2008 | 11:59 AM
  #41
i sat for an hour once making out with my ex and it never went above 210, theres def a problem
Old Dec 23, 2008 | 12:15 PM
  #42
D4u2s0t's Avatar
why do people just assume something is/isn't a problem just because it has/hasn't happend to them? it's NOT a problem as long as it goes back down...
Old Dec 23, 2008 | 12:19 PM
  #43
regardless of the make or model a modern car should never go above 220
Old Dec 23, 2008 | 12:22 PM
  #44
Cobalt Mav's Avatar
I have never seen above 210, no matter how long im sitting at a light.
  #45
D4u2s0t's Avatar
says who? the cooling fan's don't even come on at 220.
Old Dec 23, 2008 | 12:47 PM
  #46
06SS ALL DAY's Avatar
i have seen my temp up to 210 in rush hour traffic (travel through philly). but once i start moving it drops down to 174-184.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
agentirons
Oct 16, 2015 02:11 AM
Sep 28, 2015 12:51 PM
