3 codes active. fan stays on HELP!
P0098
P0480
P0532
Got my car back. These 3 codes come active instantly. Engine fan stays on. My boost gauge does not read vac or pressure. My aeroforces IAt2 read 64958 (error). All sensors seem connected. Haven't truly dissected my website and harness.
Its a 2007 SS Supercharged.
Even after car is turned off, the fans still stay on.
Recently got it back with a brand new head from dealer.
P0480
P0532
Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage = p0098
Cooling Fan Relay 1 Control Circuit = p0480
Key on or engine running, ECT sensor input less than 199°F, then the PCM detected a low voltage condition on the Cooling Fan Relay 1 control terminal, condition met for 5 seconds
Air Conditioning Refrigerant Pressure Sensor Circuit Low Voltage = p0532
Engine running, A/C has been requested, then the PCM detected an A/C Pressure sensor signal that was less than 0.1v, conditions met for three seconds.
Sounds as though the engine was started without the sensors connected, have you tried to clear and restart?
You are welcome luis. Check harness by brake resevoir
https://www.cobaltss.net/forums/2-0l...-p0532-281839/
