Abs
Abs
hey so the last couple days ive noticed not on every stop.... but when i slow from like 5 mph down to zero my abs will kick on for a brief second... its annoying as hell... doesnt happen every time but is happening more.... at light brake pedal on dry pavement... anybody have any ideas or have run into this problem before... 08 sport btw
Do you have issues with traction control as well?
its not ABS. Your rotors have areas of metal missing causing a light pedal vibration. I have it too. It definately is not ABS and I agree its strange that you only feel it some of the time. With that said, I may be wrong as its actually an un even worn pad that seats just right some of the time so you can feel the pulsing?
It won't throw a CEL, it'll throw the ABS light on. That's what mine did at least. I know the Cobalt isn't as loud as older cars, but do you hear the ABS system kick on or do you just feel the vibration?
You're probably on the hunt for some DIY advice, but just wanted to make sure to offer my assistance in the event you decide to work with a dealership on getting this looked into. In any case, I hope you're able to find a resolution for this - sounds like a troublesome issue.
All the best,
Sarah
GM Customer Service
All the best,
Sarah
GM Customer Service
I was told you can check an aircraft's anti-skid system by spinning the wheel speed sensor then stop it with the brake set. If its working the brake should cycle. I could see where this principal could work on a car as well, if you can get to where you can spin the wheel speed sensor indipendalty of the wheel that is.
BTW: Anti-Skid on aircraft is the same basic principal as ABS on a car.
I hate when cars do that. My daily had a HORRENDOUS noise coming from the front end. Sounded like it was falling apart. I crawled under and checked EVERYTHING I could think of and couldn't find the source of the noise. Drove an hour and a half to see my dad and have him see if he could figure out what it was..... As soon as I pulled in his driveway I didn't hear it anymore. It hasn't been back since.
Yea this **** happens once every time i drive longer than half an hour and he light comes on. It either comes on when I'm coming to a stop or when im sitting at the light idling
