ABS Light stays on.
Old Jun 3, 2007 | 04:59 PM
c24na's Avatar
ABS Light stays on.
Yup, it comes on about 30 seconds after i start the car..everytime. Looked up the GM service manuals and they across the wheel sensor its suppose to be withing 850-1350ohms. Tested both front wheel sensors, and they were 1535 and 1538. lol..wtf? Theres no way both went at the same time. The rears are a real bitch to testss... so.. car still under warranty..but both wheel sensors?? Anybody else have this problem.
Nate
Old Jun 3, 2007 | 05:49 PM
Mikey851's Avatar
Nate
Where did you check the sensors at? Did you check them at the sensor or at the connector? Also, did you check them after a drive or did you let your car cool down?
Old Jun 3, 2007 | 05:52 PM
alleycat58's Avatar
This is gonna sound dumb, but did you check the fuse in the fusebox. SAME THING happened on my Cavalier, would turn the car on, light would come on very shortly after turning the car on. Car had about 1200 miles on it. Result: fuse wasn't even blown, it was just loose on the connector.
Old Jun 3, 2007 | 05:55 PM
Mikey851's Avatar
Good point. Keep it simple and check the fuses out first.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Tupp
Sep 30, 2015 08:18 PM
roth
Sep 26, 2015 12:16 PM
