air/fuel questions
Old Nov 30, 2014 | 02:31 PM
  #51
Your car wouldnt run very well if the cam timing jumped
And when i say ignition im talking about the coil packs firing the plugs, not the part you put your key in
Last edited by Slowbalt2000; Nov 30, 2014 at 02:31 PM. Reason: Automerged Doublepost
Old Nov 30, 2014 | 05:15 PM
  #52
dasoftest's Avatar
No I had 2 recalls for ignition. I had one for where I put keys in and then the one for all of the electrical part I guess. So would I need to get all new coil packs? I bought all new spark plugs and stuff.
Old Nov 30, 2014 | 06:13 PM
  #53
No you shouldnt need to replace the coils lol
Old Nov 30, 2014 | 07:33 PM
  #54
dasoftest's Avatar
I'm so confused lol. What do I need to do?
Old Nov 30, 2014 | 07:41 PM
  #55
The crank relearn
Old Nov 30, 2014 | 08:07 PM
  #56
dasoftest's Avatar
The crank relearn
I'm calling Chevy tomorrow. I'll keep everyone posted.
Old Dec 3, 2014 | 11:27 AM
  #57
dasoftest's Avatar
Okay, so I'm taking the car to Chevy today and they're doing a full diagnostic. They said that the crank relearn was just for the idle timing and stuff. But they said theyd do the diagnostic for free if I got the repairs there lol. Not doing that.
Old Dec 3, 2014 | 04:40 PM
  #58
dasoftest's Avatar
Okay. Here's everything I've got, Codes are p0017, p0111, p0118, p0300.
She said timing, intake air temp, coolant temp sensor, and miss fire. What do now?
Old Dec 3, 2014 | 05:15 PM
  #59
blueLNFftw's Avatar
Things aren't plugged in right or the harness got damaged.
Old Dec 3, 2014 | 09:06 PM
  #60
dasoftest's Avatar
Shittt. So I have to essentially get a new harness. Chevy trying to say that they wanna take the front cover off and check timing and all that. I'm about to bring it back to my mechanic.
Old Dec 3, 2014 | 09:09 PM
  #61
blueLNFftw's Avatar
Did he drop in a full motor or assemble one?
Old Dec 3, 2014 | 09:18 PM
  #62
dasoftest's Avatar
Dropped in a full motor. Was brand new 0 miles so that's why I'm saying I don't see how the timing would be messed up. So I have to get him to pull motor and redo the harness?
Old Dec 3, 2014 | 09:25 PM
  #63
blueLNFftw's Avatar
Odds are slim to none a crate motor came fcked up.
It's something hooked up wrong somewhere.
Old Dec 3, 2014 | 09:34 PM
  #64
dasoftest's Avatar
That's what I'm saying. And once it starts it runs outstanding except the a/f dropping to 10.2. And it's weird cause he used the same harness and everything. Is there anyway to do it without pulling the motor or no?
Old Dec 4, 2014 | 07:52 AM
  #65
blueLNFftw's Avatar
Where is Florida are you exactly?
Old Dec 4, 2014 | 10:01 AM
  #66
dasoftest's Avatar
I was gunna ask you the same thing lol. I live in Port Saint lucie. It's about 45 minutes north of West Palm Beach.
Old Dec 7, 2014 | 10:34 AM
  #67
mrbelvedere's Avatar
P0017 Crankshaft Position (CKP) - Exhaust Camshaft Position (CMP) Correlation - ECM, PCM
P0011 Intake Camshaft Position (CMP) System Performance ECM
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage -PCM
P0300 Engine Misfire Detected -PCM
p0017 is more then likely a misstimed cps housing(could be out of time engine butit was a complete unit)
p0118 is more then likely a bad temp sensor or wire if either is the case the engine will not come out of rich warm up and cause the car to run rich all the time
p0300 from running rich
p0117 i have no idea unless the engine os out of time
Old Dec 7, 2014 | 10:37 AM
  #68
as you can bolt an lsj head onto an lnf and yes it will run but not well as the crank relucter is 12deg retarded take a good pic of the oil cooler and post it up
Old Dec 7, 2014 | 11:27 PM
  #69
dasoftest's Avatar
Well she starts right up again. Mr.b was right. Crank sensor was off. A/f still goes low sometimes but other than that it runs perfect. Getting code for multiple random miss fire. Gunna get new coil packs and see if that helps. Thanks everyone for any input given its appreciated.
Old Dec 8, 2014 | 08:25 AM
  #70
you threw a temp sensor code if the computer can see temp it will run rich
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
