Another cobalt down. engine blown.
Old Feb 2, 2007 | 02:59 AM
beamSS's Avatar
i just wanted to let you know that i just found out that most probably i blew my ringlands.
i've been running 2.8 with 60# for 8k miles+custom tuning and 5kmiles with 42#+ custom tune. what do you think was my problem. i dont think im running lean cuz my tailpipe is dirty but who knows. what do you think happen here? im going diamond pistons,cometic headgasket, ARP's. im sticking with 2.8 cuz i dont want this crap again cuz im planning to trade for an evo or vette next year.
Old Feb 2, 2007 | 03:10 AM
sunfirejoe's Avatar
lean conditions id say but who knows
Old Feb 2, 2007 | 06:12 AM
JapEatr's Avatar
South Central *********
how do you know the ringlands are blown
also i have the 2.8 w/stg 2 flash, you think its a fluke?
and you had 60# injectors when it failed? Bad Tunes?, Too much timing?
Old Feb 2, 2007 | 06:59 AM
1gmfanatik's Avatar
I think it may have been a tuning issue, that's what alot of the blown engines have stemmed from.
Old Feb 3, 2007 | 12:18 PM
c24na's Avatar
Who did your tunning? Did you have a stage 2?
more details
Old Feb 3, 2007 | 12:28 PM
SilverSS/SC's Avatar
A dirty tail pipe isnt really a good indicator . Your likely running pretty rich out of boost and light driving and lean up top . My SS runs rich enuff down low to about blacken my whole back bumper , but on my last dyno it leaned out to 12.5-13.0:1 between 5500-7K . That was in 60* air . Given that fact that it been so damn cold here , I have not gone anything past 1/2 throttle .
What combo was in the car when u popped it ?
Old Feb 4, 2007 | 10:39 PM
quad4racer's Avatar
i guess nobody believes in widebands
Old Feb 4, 2007 | 10:42 PM
Allshot's Avatar
Wow you are running dangerously lean up top......I'd be scared if i were you.
Old Feb 4, 2007 | 10:46 PM
CobaltSS422's Avatar
or an aeroforce interceptor... i have my inteceptor showing boost and KR all the time and i'm always checking the DTC's... as soon as i see KR i let off the gas especially with how cold it is here in buffalo
Old Aug 19, 2007 | 11:44 PM
Shanman's Avatar
i have a problem car is at the dealership and to say the least my #3 plug smells a lilsweet i know it's a dangerous setup to go with but i've had my 2.79 pulley on w/stg2 ever since i had the car and ever since i did i the 2 pass mod i think i have been really maxin the **** out of my injectors b/c when it gets past 6500 the car starts falling on it's face and i didnt get the endplate done at the dealership i was wondering if they could void my warranty for not having it installed by a gm technician
if so what should i do to keep my warranty i only have 18000 miles on the car
come on guys i really need help and i'm not a premium memberi f i can't get noticed not being 1 then i guess thats wat it'll have to take
Old Aug 19, 2007 | 11:58 PM
rnjmur's Avatar
Even with a good tune you are probably going to run lean with anything smaller then a 2.9 with 42# injectors.
Shanman: They really can't void your warranty unless they can prove anything you did caused a failure. Running a 2.79 with the stage 2 tune is really not a very good idea, and if you have a problem that is probably going to be the cause.
Old Aug 20, 2007 | 12:25 AM
Doc's Avatar
Doc
Running the stock manifold or a header..??
Either way, what does it look like inside..??
Old Aug 20, 2007 | 12:56 AM
beamSS's Avatar
you should have taken that 2.79 before you went to the dealership. when i blew my piston i didnt even bother. i went straight to a mechanic and had my pistons replaced. forged btw. cost me 3000 for parts and labor.
Old Aug 20, 2007 | 01:01 AM
Doc's Avatar
Doc
whoops... would have helped if I read the original date anyway...glad your back on the road now.
Old Aug 20, 2007 | 07:59 PM
Shanman's Avatar
good news i didn't blow it! strait from the paper. Pulled valve covers and found #3 rocker arms off due to adjusters/lifters broken due to High RPM over rev. Replaced adjusters on #3 cylinders valves. They also told me since this is the 2nd time I've taken it for "overrevin" then the next time warranty won't cover it. 1st time was my fault (downshiftinto 2nd at 105) but the rockers fell off so they just put the rockers back on and i knew that that **** wasn't gonna be good for long so i'm just gonna baby it for a while and hopefully no other adjusters will break off
2.79 pulley actually says 77.9 which is the size of the stg2 pulley and i never had this setup installed i bought the car like this
Old Aug 21, 2007 | 12:33 AM
1gmfanatik's Avatar
Why in the hell would you downshift into 2nd at that high a speed?
Old Aug 21, 2007 | 12:35 AM
lsjwannabe's Avatar
he really wanted the power lol thats almost to high for 3rd
Old Aug 21, 2007 | 12:45 AM
BlacKRioT's Avatar
lol that is effin crazy your lucky your pistons didn't fly through ur hood of your car.........why would you do that....curious....
lsjwannabe's Avatar
probably went to grab 4th and downshifted some how i would guess
Old Aug 21, 2007 | 12:54 AM
1gmfanatik's Avatar
I know really..I think I have shifted to 3rd at around 80 or so but not at any higher speeds. He had them problems comin.
Powershifting into 4th and missed?? Shouldn't be powershiftin at those speeds anyways..JMO though
Last edited by 1gmfanatik; Aug 21, 2007 at 12:54 AM. Reason: Automerged Doublepost
Old Aug 21, 2007 | 12:55 AM
lsjwannabe's Avatar
yeha i totally agree i never go past 3rd when im getting on it anyway thats more than fast enough for me
Old Aug 21, 2007 | 09:04 PM
Shanman's Avatar
wtf u think i meant 2 do that? hell no i was racing a camaro ss and bounced off the gate and instead of it going into 4th... well u know i was pretty pissed that that i didn't feel it in 2nd cause i sware i felt like i was in 4th but right when it threw me into the steering wheel i knew wat happenned and i hit the clutch, but i was in 2nd for almost 2 secs... amazing engine to only throw off a rocker.
Old Sep 9, 2007 | 02:30 AM
eastcoastz's Avatar
Finnally someone else did what I did about a year ago! I down shifted into 1st at like 60mph and shattered 3 lifters!! Drove the car like that for two weeks and not one engine code. 2 Chevy dealers told me the car was fine that it was something I did with a custome tune lol!
How to Guide
57
Oct 15, 2015 11:56 AM
Highgross89
20
Sep 11, 2015 03:24 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
