Bad Grinding On Left Turns
Old May 1, 2006 | 10:35 PM
BooSSted's Avatar
So, I am on my way home tonight and I throw the car into a left turn pretty hard and I get that INSANE grinding noise coming from the front left of the car. It scared the crap out of me. I pulled over and checked the wheel and everything and it was all tight. I continued to drive home and I took a couple rights and there was no noise. Then I took another left onto my street and I get the grinding noise again!
Anyone know what could be causing this? Could it be the Ingalls Engine Torque Damper?
Old May 1, 2006 | 11:00 PM
zinner's Avatar
Moderator Alumni
Check your wheel shroud. Mine rubs too and I think it's my intake (K&N).
Old May 1, 2006 | 11:26 PM
srt-killer's Avatar
Do you have a LSD cause that can cause a grinding noise when turning. When that happend to mine i took it to the dealer, the tech told me it was the LSD trying to lock up the wheels.
Old May 1, 2006 | 11:35 PM
biniecki's Avatar
A friends of mine had a similar problem with his ION redline but in the rear end. Turned out the caliper was sticking from time to time for whatever reason
Old May 1, 2006 | 11:40 PM
Zonomar's Avatar
My front passenger snow tire rubbed against the trim along bottom of fender (inside rear of wheel well).
The one screw inside the wheel well holding it was too tight from factory - it is warped just a bit inside wheel well now.
Rubbed the blue paint off the black plastic a bit - can't be seen unless you kneel down with the wheel off.
Old May 1, 2006 | 11:42 PM
CobaltSS422's Avatar
I get that
Blown 4-banger's Avatar
I have the same thing, but only when i turn sharp or with the brakes on
Old May 2, 2006 | 12:05 AM
BooSSted's Avatar
I have LSD so I guess it could be that. I don't think the tire is rubbing anf it isn't the Intake because it is coming from the right of the car.
I am going to listen for it fro a couple days and see if I hear it again. Tonight was the first time.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Oct 13, 2015 09:32 PM
roth
Sep 26, 2015 12:16 PM
