Bad hesitation shifting between gears
Old Aug 20, 2017 | 09:07 PM
Johnny Bliss's Avatar
And it's seems to be getting worse.
On toruqe app I can see the timing going from normal to like single digits or even -6 or around there sometimes.
It bucks when it does this. Very annoying. I know the torque management does this but should it do it that much?
It runs smooth when the car is cold like when it's in open loop....
Lead sme to believe it's some sensor. I've cleaned the tb and maf and new plugs
Anything else in in torque I could use to debug it?
It's really annoying me. Maybe primary o2 sensor??? Map?? Something...
Old Aug 21, 2017 | 07:16 PM
cluelessk's Avatar
Trim, mods, tune, CEL?
Did you turn the the tb while cleaning? You may have ruined it if you did.
What you provided is almost useless.
Old Aug 21, 2017 | 07:29 PM
GM stage 2
aem filter/airbox mod whatever
no cels
what do you mean turn the tb?
Old Aug 21, 2017 | 07:37 PM
btw it did it before i cleaned the TB. i cleaned it to try and get rid of this issue
Old Aug 22, 2017 | 10:06 AM
jdbaugh1's Avatar
You have GMS2 tune on there as well? Have you checked your Air/fuel ratio (LSJ cars have stock wideband correct?)
Old Aug 22, 2017 | 02:01 PM
Wish it had a wideband in the primary stock. It's a narrow band and just by watching the voltage it's running rich all the time. 10-11:1 but a narrow band isn't reliable :/
If it had a wideband it would def give me a lot of insight. It loses some pep it feels like when it enters closed loop. When it cold it feels pepper and not just because of cooler air... Just crusiing the exhaust is deeper and feels better part throttle. I might just throw a new o2 in there to see if it helps a narrow band shouldn't be expensive.
Old Aug 22, 2017 | 02:03 PM
jdbaugh1's Avatar
You know who did the tune for sure?
Old Aug 22, 2017 | 03:57 PM
99%
Old Aug 24, 2017 | 12:41 AM
I put a new fuel filter on and on first drive it seems better. We'll see tho
Old Aug 24, 2017 | 01:08 AM
cluelessk's Avatar
Keep throwing parts at it.
You'll fix it eventually. Right?
I get people trying to save some money by working on their own cars but the majority would be way better off paying a professional.
Source - Autobody tech that's seen some DIY ****.
Old Aug 24, 2017 | 03:02 PM
all this **** needs to be replaced anyways
a mechanik would just do the same thing and charge me 4x what it actually costs
Old Aug 24, 2017 | 03:25 PM
jdbaugh1's Avatar
Putting on a new fuel filter isn't really a bad idea as it is a cheap easy thing to do and it can only help. I would think if fuel delivery was your problem you would lean out and lose power in the upper RPM range. I know you mentioned you had an OBD scanner that works with your phone. Have you checked the long term and short term fuel trims?
Old Aug 24, 2017 | 08:45 PM
cobaltssdude420's Avatar
Originally Posted by Johnny Bliss
GM stage 2
no cels
He means move the throttle plate
Old Aug 28, 2017 | 05:48 PM
car runs well except for this little issue. idles perfectly at ~800rpm
it seems to do this hesitaton between shifts and bogging when its very hot. it was ~100f here last couple of days and city driving in the heat is where i feel it the most.
really annoys me, i'm used to driving ls (4th gen) v8 cars and they run smooth as glass all the time... even with 200k miles.
my old man's 1999 197k mile ls1 camaro runs smoother than my 07 cobalt. some of that is just because its a 4banger but seriously it shouldn't have all these studders and ****
Old Aug 28, 2017 | 07:02 PM
cluelessk's Avatar
V8's are inherently balanced. They'll always be smoother than an I4.
Have you tried cleaning your maf? I had a small misfire around 3000rpms with light throttle. Ended up just being oil from my Filter on my maf.
Old Aug 28, 2017 | 07:06 PM
yeah i know but it still shouldn't stumble like this.
i did clean the maf with some maf cleaner.
the air filter on it is pretty old... and shitty i have a new one i guess i should try and put it on and see what happens.
Old Aug 28, 2017 | 07:13 PM
cluelessk's Avatar
Good idea. Might as well get new maintenance items. Have you checked all your vacuum lines? These cars are getting older and rubber can break down.
Old Aug 29, 2017 | 01:18 PM
i replaced the vac line from that goes to the bypass on the s/c. the other ones look fine
the vac on the gauge looks normal to me and it never fluctuates.
Old Aug 29, 2017 | 01:31 PM
jdbaugh1's Avatar
Have you checked your fuel trims yet? That will be a good indicator to at least get you pointed in the right direction as far as diagnosing the cause.
Old Aug 29, 2017 | 01:35 PM
yeah i did the ltft was -3% iirc
the stft was . something. i'll look in a few mins and update post. kid has my phone
Old Aug 29, 2017 | 02:23 PM
Ltft says -5.47 an after I took a drive to the gym which is about 2 miles it says -7% now
Old Aug 29, 2017 | 04:17 PM
the ltft bounces around from -7 to +8 and just bounces around
the stft bounces from -7 to +12
this is all while driving
Old Aug 29, 2017 | 09:08 PM
I think the new air filter fixed it. The ltft is much better now it was sitting 0 to 3.3 but 90% of the time it was 0.3 or 1.6
Seems to run better.
Old Sep 10, 2017 | 02:19 AM
Eh was doing it a lot less but kinda still.... But it completely shut off driving down the road won't start...
Won't start no spark... Can't get sensor until Tuesday ug
Old Sep 10, 2017 | 11:13 AM
cluelessk's Avatar
change the crank position actuators
