Bad spark blowout
Old Jul 16, 2013 | 12:45 AM
killswitch1209's Avatar
Bad spark blowout
Ok I have a built l61 2.2 on 18-20 psi boost on e85 I have bin recently running great till i got a tune up from my budys shop fix all vac/boost leaks it was with iridium plugs 2 steps colder gapped to .27 for over a year I recently swapped a LSJ THrottle body now I'm getting bad spark blowout in lower gears 1-3rd gear at lower boost pressures 4-7 psi it breaks up pretty bad then kicks back in higher boost I swapped some 2 step colder vpower plugs gapped to .26 same thing gonna swap them again tomorrow with less tight gap what els could be the issue??!
Old Jul 16, 2013 | 12:48 AM
SalvageBaltSS's Avatar
Go back to your other TB and see if it still does it.
Old Jul 16, 2013 | 01:20 AM
My old throttle body was just cutting out at 4500 or 5psi wouldn't go past now it's better but completely fixed the issue
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Iceberg
Sep 29, 2015 12:33 PM
