Bleeding coolant?
Old Apr 21, 2020 | 09:35 PM
1SlowBaltSS's Avatar
Bleeding coolant?
just curious about the best method to bleed the coolant system of air. Going to be doing a stage 3 kit install on my car this weekend and will need to get all the air out of the cooling system afterwards
Old Apr 22, 2020 | 07:52 AM
jdbaugh1's Avatar
Stage 3 radiator kit?
Old Apr 22, 2020 | 09:16 AM
Stage 3 kit from zzp. Putting another heat exchanger on
Old Apr 22, 2020 | 09:36 AM
jdbaugh1's Avatar
Oh alright so not your engine coolant system but the heat exchanger system. Your stock heat exchanger should have a little brass plug in the top of it that you can use to let out trapped air. Do you have opt. B reservoir or just filler neck?
Old Apr 22, 2020 | 09:39 AM
BlackielawlessSS's Avatar
If it doesn't work, Try hitting it.
Old Apr 22, 2020 | 09:48 AM
just the filler neck in assuming. Car Is mostly stock. So the supercharger cooling system is completely separate from the cars engine cooling system?
Old Apr 22, 2020 | 11:13 AM
jdbaugh1's Avatar
Exactly. Heat exchanger circuit operates at much cooler temperature than engine coolant system.
Old Apr 22, 2020 | 11:42 AM
i gotcha, thanks for your help man
boostbalt
Aug 17, 2012 02:31 PM
nismopowerdqg
Jun 26, 2011 09:25 PM
ROTARYFDTT
Dec 2, 2010 06:24 AM
Ting-ting
Nov 4, 2010 12:33 PM
