Blinker on a 07 2.2L Coupe
Old 02-22-2011, 05:22 PM
Phil424's Avatar
I notice whenever I use the signals they do work and flash, but there is no clicking noise of the circuit opening and closing..and from what I can tell there is some kind of flasher module or something? Have not got my haynes manual yet..just something I was curious about. Is there a way to enable or disable it?
Old 02-22-2011, 05:23 PM
padlock's Avatar
you have an aftermarket radio?
Old 02-22-2011, 05:45 PM
Phil424's Avatar
Nope its factory
Old 02-22-2011, 05:58 PM
padlock's Avatar
well no idea then.. bump for answers
Old 02-22-2011, 06:57 PM
07cobaltLScoupe's Avatar
did you check your driver door speaker yet? the chimes/alerts come out of that speaker.. i had this happen to me and it was actually that the speaker was blown, i got it fixed while i was still under warranty...
Old 02-22-2011, 07:00 PM
ilovecars's Avatar
x2 on the door speaker.
Old 02-22-2011, 08:40 PM
well if your speaker works fine then i'm not sure what it is, maybe check your fuses?
Old 02-22-2011, 08:45 PM
09xfebalt's Avatar
you can change the volume :The radio is used to adjust the vehicle’s chime level. To change the volume level of the chime, press and hold the preset push button 6 with the ignition on and the radio powered off. The volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold the preset push button 6 again. The volume level will change from the loud level to normal, and NORMAL will appear on the radio display. Notice: Each time the chime volume is changed, three chimes will sound to indicate the new volume selected.
Old 03-01-2011, 11:54 PM
Phil424's Avatar
Turned out my driver side speaker is blown. If I raise the volume of the music, and then lower it the speaker will work then go out and come back. Going to order some speakers from crutchfield.
Old 03-02-2011, 11:28 AM
KillinKrullin's Avatar
no no no, this is waaaay simpler than that....
change your blinker fluid, DUHHHH
Old 03-02-2011, 06:16 PM
C_A_D88's Avatar
did not know that
Old 03-02-2011, 06:23 PM
shoes-780's Avatar
i had an 06 cluster and it makes that click thru the speakers but on the 07's its in the cluster, mine does it too,do you have hids?
Spanky's Monkey
03-07-2016 06:06 PM
ThoR294
10-04-2015 08:44 PM
Tupp
09-30-2015 08:18 PM
09-26-2015 06:44 PM
jmelton327
09-24-2015 01:40 PM
Quick Reply: Blinker on a 07 2.2L Coupe
