Blown Head Gasket??? HELP
Old Dec 24, 2011 | 01:41 PM
bratboy90's Avatar
Unhappy Blown Head Gasket??? HELP
I'm going to run down the whole story so there aren't any questions later.
Nice day out here in Minnesota, prob 20 degrees out, always allow my car to warm up too 120 AT LEAST before driving. Going to DVM to get tabs, car is running fine. Get tabs, get in car. Girlfriend is driving because I have a massive hangover. She's no nembie to clutching, but she kills the car. Whatev's restarts it and check engine is on.
Get to Walmart, buy oil to do an oil change. Leave Walmart, head to advance to use OBD reader for free. I'm assuming cyl 4 misfire because it has been randomly misfiring.
It was. Oh yay, check into it again later I thought.
Go get some pizza, go home. Got to work.
Leaving work. Warmed car up to 160 before driving. Car still acting a little funny. I pulled a stupid and said **** it, WOT run to get rid of the damn misfire. Bad choice.
Pulling wot, no traction, but keeping around 5,500rpm get into 3rd drops to 3,500rpm because I early shifted due to no traction, slowely builds back up, and around 6k check engine is flashing, loss of power. Now something was really wrong.
Get to next stoplight, and car dies on me. Restart, now my heater smells like ****** flowers(Sweet, aka coolant). ****. Pull over in safe location, car dies on its own again.
Restart once more just to diagnose with engine open, see if a hose came loose. NOPE.
No metal flakes in exhaust.
No hoses leaking or leaking sound.
VAC on boost gauge is at 14-15. Usually 19 or less(high reving tune BLEH)
Car is reving like a Subaru with exhaust
Antifreeze in my oil, but not the opposite(yet).
Towed car home. Sitting in driveway, putting in garage to look at after X-MAS.
Anyone got some knowledgeable input. I've asked my car buddies and it sounds like a head gasket was leaking and WOT destroyed it.
I also will be replacing my tensioner, its been ticking sometimes been lazy.
Anyone know of a HOW TO on taking apart the motor down to the head gasket?
Can I also easily replace my O-rings while I'm at it?
I'm pretty good with motor stuff, just haven't even had to take apart a car motor, just snowmobiles thus far. I have plenty of support from my nearby fellow Cobalterz already.
I really appreciate any help guys.
Thanks,
Crying* Bratboy90
Old Dec 27, 2011 | 04:42 PM
bratboy90's Avatar
So..... Got around to taking apart the motor.
1. Slightest bit of antifreeze in oil (very slight, so I doubt the head-gasket is to blame)
2. Compression Dry is (left to right looking at motor from front bumper)
180, 180, 180, 0
____________^NOT GOOD
I'm in strong belief that I have blown a hole through the piston, cracked the sleeve, and/or a bent a valve.
Looking into replacing motor completely and keeping for a future build.
Will continue taking apart and update with pics of damage.
Old Dec 27, 2011 | 04:46 PM
zerosk8ter83's Avatar
bad injector?
Old Dec 27, 2011 | 06:52 PM
nhanson's Avatar
what you mean bad injector?
see this thread: https://www.cobaltss.net/forums/2-0l...4-dead-268130/
Old Dec 27, 2011 | 08:24 PM
calicobaltSS's Avatar
sounds like a ring....if your not getting ANY compression....Id try a leak down test....its either gonna be the ring or sometihng in the head....
Old Dec 28, 2011 | 12:34 AM
nhanson's Avatar
Were in the tear down stage.
Old Dec 28, 2011 | 07:38 PM
bratboy90's Avatar
Being this is Cyl 4. Cyl 4 had blown in the past on this car. GM covered it. I'm at 84k now. GM won't cover this damage even though they should admit I got a lemon part somewhere in the motor from the start. Girdled block here I come
Old Dec 28, 2011 | 10:24 PM
Pics!!!!!!
Old Dec 28, 2011 | 10:36 PM
nhanson's Avatar
there will be pics
Old Dec 29, 2011 | 02:59 PM
bratboy90's Avatar
Here's a video of it idling and a slight rev to about 2,300rpm.
http://www.youtube.com/watch?v=gCMyPAyx9pw
Old Dec 30, 2011 | 12:44 AM
Thaaaaat dont sound too good........no bueno!!!!
Old Dec 30, 2011 | 01:00 AM
Chybaby7's Avatar
Sounds kinda like a boat out of water lol
Old Dec 30, 2011 | 05:04 AM
SCobaltblu's Avatar
Girdle that bitch!
Old Dec 30, 2011 | 05:29 AM
nickadolph's Avatar
Sounds like my ninja
Old Dec 31, 2011 | 03:36 AM
bratboy90's Avatar
OK. So detonation occured. Immediatly taking it out on the piston ring, which scored the sleeve, and damaged the piston. I'm no genius on valves, so I'm unsure if damage has occured, but I'll have someone look at it. We were expecting a lot more damage than actually occured. But still this requires a new motor or girdled. Looking into it, thanks for the support. Pictures below.
PICS:
Again, Thanks.
Old Jan 1, 2012 | 05:10 AM
SCobaltblu's Avatar
Numbers 3 and 4 look like they got hot according to that gasket!
Are those aftermarket pistons?? Looks like they have valve reliefs.
Old Jan 1, 2012 | 02:06 PM
nhanson's Avatar
how can you tell that from the gasket?
also how can we tell what pistons they are?
Old Jan 1, 2012 | 02:23 PM
Superbalt06's Avatar
The stock ones will say mahle on them. (pistons)
Old Jan 1, 2012 | 03:04 PM
nhanson's Avatar
On the face of them?
Old Jan 1, 2012 | 03:13 PM
Underneath.
Old Jan 1, 2012 | 03:21 PM
bratboy90's Avatar
The Mahle performance ones don't have valve reliefs on both sides, when I pull the motor out, I will let everyone know what they are.
Old Jan 1, 2012 | 03:35 PM
The picture looks like those are diamond pistons.
Old Mar 16, 2012 | 04:13 AM
ralliartist's Avatar
those definitely are not stock pistons.
Old Mar 17, 2012 | 04:36 PM
nhanson's Avatar
We will see what the rods are pretty soon
Old Mar 18, 2012 | 12:50 PM
FasterIsBetter's Avatar
Blew my headgasket recently on my car as well. Mine def doesn't sound that bad tho, no misfiring or anything. Just a knock from coolant in the oil/low oil pressure.
Trav3480
Oct 1, 2015 08:17 PM
ThoR294
Sep 28, 2015 05:31 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
