Boost Flutter at 4000RPM's and above!
IF YOU HAVE A VACUME CAP PULL THE VACUME TUBE OFF THE UPPER PORTION OF THE ACTUATOR THATS ROUTES TO THE OUTPUT OF THE BOOST CONTROL CYLINOID VALVE (FRONT, FACING YOU) THEN CAP OFF THE OUT PUT OF THE BOOST CONTROL CYLINOID VALVE AND LEAVE THE TOP OF THE ACTUATOR OPEN TO ATMOSHPERE! TRY A PULL LIKE THIS IF THIS CURES YOUR PROBLEM THEN YOUR IN THE SAME BOAT AS ME?
ok im not "mechanically inclined" but i like to hit 200km in fourth gear just like the rest of you, so for all the techies out there riddle me this, why does my exhaust (vibrant cat back loudmouth) have so much re verb almost to the point of sounding like a backfire or even like a srt 4, i have a k&n tyfoon, stage 2 kit and the cat back system i have no noticible lack of power but when i hold the pedal steady at about 3000 or 4000rpm and then let go she pops and bangs as she winds down WTF is going on is that normal, do i need more compression better fuel or a new chevy any takers, i will truley appreciate any advice that i get thanx
I thought the more open you make your exhaust the more you will lose boost cause it opens the out go flow so the charger doesnt have to work so hard? (not directed at the guy with no boost)
ok I'm not "mechanically inclined" but i like to hit 200km in fourth gear just like the rest of you, so for all the techies out there riddle me this, why does my exhaust (vibrant cat back loudmouth) have so much re verb almost to the point of sounding like a backfire or even like a srt 4, i have a k&n tyfoon, stage 2 kit and the cat back system i have no noticeable lack of power but when i hold the pedal steady at about 3000 or 4000rpm and then let go she pops and bangs as she winds down WTF is going on is that normal, do i need more compression better fuel or a new chevy any takers, i will truly appreciate any advice that i get thanx
Could be that when you let off the gas so quickly the spark turns off and the injectors are still putting out some gas and its igniting in the exhaust.
Or the valve timing is so advanced that it when you let off quickly the exhaust vales are still slightly open when the gas is ignited in the cylinder when you winding down.
that makes sense... sort of, it would definately explain carbon build up around exhaust tip , so is that popping and banging bad, good or niether, what could i do to stop it from doing that, mabey a header? it sounds like a srt 4 neon all garggly and throaty it sets off carr alarms 100 feet away and wakes my neighbors up in the mornings ha ha
i never had exhaust on any of my cars before, i went out w some guys last night and they said it sound good, so i guess its not that bad, i just want to tighten it up a bit and im sick of cleaning and replacing my exhast tip all the time. if im running to rich how would i solve that, any way i love the way it scares the **** out of little old ladys on their power chairs, oh and my neighbors love it to
if your having problems putting it into reverse let out the clutch a bit, same for first, i dont know if its supposed to work that way, but it works, at least it should
Awh Ha.
THE TICKING IS THE INDICATION THAT YOUR CAT HAS SLIGHT MOISTURE DURING START-UP AND IS STEAMING IN CAT CAUSING A POPING NOISE UNTILL IT EVAPS.
I WENT TO DYNO AT BMG FOR COBALT MEET ON SATURDAY I DYNO'D 239WHP AND
198FTB WITH NO TUNE, STOCK PULLEY, STOCK INJECTORS. I PORTED AND POLISHED MY SUPERCHARGER AND I INSTALLED A PACESETTER LONG TUBE 1.75 PRY HEADER AND BUILT CUSTUME DOWNPIPE CATLESS WITH FLOWMASTER 40 SERIES EXHAUST. NOT BAD #'S THIS SAT COMING UP FRED AT BMG IS GOING TO INSTALL MY 2.7 ALONG WITH 60LB INJ AND I PUT IN METH INJ AND DUAL PASS WITH BIG FRONT MOUNT. WITH AN AGRESSIVE TUNE I'LL HIT 300WHP/TRQ. I'LL KEEP YOU POSTED!
I'VE SPENT A TOTAL OF 450 DOLLARS! AND GAINED 100HP/TRQ!!!
[SIZE="4"][COLOR="DarkOrange"]Your right the car wont go past 3500 rpms with out the ecu putting it in protection and all my timing goes away along with my horse power? Before 3500 rpms I made 258ft of trq and 260hp at the wheels! SO YOU DO THE MATH JUST REMEMBER I HAVE A PORTED AND POLISHED SUPERCHARGER AND A METH KIT ALOND WITH A GOOD TUNE!!!!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
