boost issues
boost issues
I have a 2005 Cobalt ss s/c it has 114xx miles. When i first bought the car I new it had few problems. But one I cant figure out is I cant boost over 8 to 9 psi. Then randomly ill start boosting around 13 psi but then I pull -10 on my vvaccume No mods becides cold air intake and exhaust. I replaced mass air flow and 02 sensor I pulled off throttle body and cleand it too. Could the by-pass vale cause this or would it be the by-pass valve ssiloned.
Unbolt your bypass valve and WD40 it and if that doesn't fix it then try getting an new solenoid from CED. My LSJ was only doing 3 psi at WOT after the WD40 I'm at 16 psi
