boost issues
Old Jan 31, 2014 | 06:35 PM
ssrogers's Avatar
boost issues
I have a 2005 Cobalt ss s/c it has 114xx miles. When i first bought the car I new it had few problems. But one I cant figure out is I cant boost over 8 to 9 psi. Then randomly ill start boosting around 13 psi but then I pull -10 on my vvaccume No mods becides cold air intake and exhaust. I replaced mass air flow and 02 sensor I pulled off throttle body and cleand it too. Could the by-pass vale cause this or would it be the by-pass valve ssiloned.
Old Feb 1, 2014 | 12:28 PM
ssrogers's Avatar
Could really uses some help??
Old Feb 1, 2014 | 12:59 PM
UltraSilverSS's Avatar
WD40 the rod on the Bypass Valve it may be rusted costs about $5. If not replace the Bypass solenoid Costs About $55. If not you may have a leak somewhere.
Old Feb 1, 2014 | 10:20 PM
ssrogers's Avatar
If u replace the solenoid and that does not fix the problem. Then should I replace the valve it self?
Old Feb 1, 2014 | 10:23 PM
BlackielawlessSS's Avatar
Clogged cat? Bad fuel filter?
Old Feb 2, 2014 | 01:26 AM
Unbolt your bypass valve and WD40 it and if that doesn't fix it then try getting an new solenoid from CED. My LSJ was only doing 3 psi at WOT after the WD40 I'm at 16 psi
Old Feb 2, 2014 | 02:27 PM
ssrogers's Avatar
Cat and fuel filter are fine. I have checked into both of them
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
