boost issues
boost issues
So I recently just bought a ss sedan turbocharged from my buddy it wasn't making boost but makes noises as the turbo and intake are still working correctly. I went and ran the code at autozone p0101 which is Maf sensor, I bought a new maf sensor and they didn't solve the problem I also bought a new purge selanoid that didn't fix it either. I checked all the couplings on the charge pipes and the intake and everything seems to be fine. Anyways after I fixed the maf and purge selanoid I took it for a ride got up to 20 lbs of boost twice then the 3rd pull no boost at all.. Idk what this could be.. Plz help.
Tighten all the clamps still no boost tried the water and soap vacuum leak test and I found nothing. I found I do have a exhaust leak were the cat back meets the muffler. I don't think that would be the issue though... Help...
I didn't do the Boost leak test yet. I did the water and soap and sprayed all the vacuum lines and I didn't notice any leaks. My vacuum is at 19 and kinda moves back and forth while I'm ideling... What do you recommend..
Soap and water won't bubble up during an idle because you are drawing a vacuum. You need to do the boost test and pressurize the system, then with the system pressurized use soap and water. Any leaking air will make bubbles. I am willing to bet you won't need soap and water and you'll hear the leak.
What kind of bolt-ons do you have? Or are you stock
yes do a boost leak test, u can check the clamps all u want, u wont find the leaks without doing a boost leak test, some may only show up at a certain psi, some may show up right away. as soon as u put compressed air into the system u will hear the leaks if there are any.
Making a boost leak tester is realitively cheap and its a tool you can always use on these cars to troubleshoot and will save you a lot of head aches down the road. I can't even tell you how many times I've used mine
Looks good. Just make sure...that whatever compressor or how ever you are pressurizing your system, bring that **** down to like 15-20psi or you will blow things apart...
