Boost issues..Help quick
Old Oct 9, 2008 | 09:08 PM
fzn14's Avatar
Red face Boost issues..Help quick
Recently installed the OTT stage one which is the 60 pound injectors and 2.8 pulley with minor tuning. So to took off my throttle body to clean out the carbon despoists inside to hopefully help with my idle and what not which it did. But on my way to work i went to get on it and it went up to 15-17 pounds but then bleed off to around 12. Does this threw all gears. So on my break i went out and messed with the vaccum line connected to the throttle body and seemed to semi help...Boost seems sluggish in 1st. holds 14-15 in 2nd and in 3rd goes up at 15-17 but then bleeds off again down to about 12...So with that in mind. Does anyone have any ideas what this could be? I tryed re adjusting my throttle body and what not and unplugged things and plugged them back(the hard line coming off the throttle body). I was thinking maybe the bypass valve is not opening and closed like it should or something along those lines. Idle is normal and does not jump around, so which pretty much rules out vaccum leak. As well as there is no normal driving issues. Only when boosting...Any help?
Old Oct 10, 2008 | 03:29 PM
standan's Avatar
your boost bleed off problem is a safety valve...just like a BOV...superchargers need ways of diverting high boost so it doesnt damage anything. id be looken into that before throttle or vaccum problems
Old Oct 11, 2008 | 07:04 PM
fzn14's Avatar
Where is this located? is it the actuator on the supercharger?
Old Oct 16, 2008 | 10:02 AM
standan's Avatar
The PCM controls your boost solenoid. The solenoid controls vaccum to actuate the bleed off valve. It is located on the right side of the supercharger. Theres two vaccum hoses going to it. A PCM programming would be recommended. You could bypass the solenoid letting your foot control boost but thats when bad stuff happens and u could over boost causing damage to who knows what. If it bothers you that much and u got the dough find a program for the pcm and let more boost get to engine.
Old Oct 22, 2008 | 04:10 AM
fzn14's Avatar
Got a tune by area47 and still has the issue. CAN HTP tuners help with this?
Old Oct 22, 2008 | 04:16 AM
cakeeater's Avatar
you are talking about the bypass valve. that is not there for surging or overboosting as positive displacement sueprchargers don't really "surge" like a turbo or centrifugal supercharger. are you using the stock supercharger belt?
Old Oct 22, 2008 | 04:28 AM
Raven SS's Avatar
the psi is taking from no where near the boost bypass...maybe ur gauge is failed
fzn14's Avatar
I cant runnign 2.8, I am running GM stage two belt..I just read something about bypass screw adjustment...Any thoughts?
Old Oct 22, 2008 | 01:10 PM
standan's Avatar
if u have the gm product...it should be warranty approved...how many k's on the car?..id let them diagnose it and let them tell you what it is...so u can fix it
Old Oct 22, 2008 | 01:45 PM
Area47's Avatar
Rent me! per hour
you have a mechanical issue. there is nothing in the file itself that will kill the boost in certain gears. get a log done and look at the boost itself. also. see the stl thread ABOUT what i did to the car.
Old Oct 22, 2008 | 01:48 PM
lsjwannabe's Avatar
Never heard of this issue before with our stage kit sounds mechanical to me, do you have a log you could shoot my way?
Old Oct 22, 2008 | 01:55 PM
Area47's Avatar
Rent me! per hour
sean. i can send you the file itself.
Old Oct 22, 2008 | 01:56 PM
lsjwannabe's Avatar
you still have my email? if not i will shoot you a pm
Old Oct 22, 2008 | 01:59 PM
Area47's Avatar
Rent me! per hour
yew haz pmz
Old Oct 22, 2008 | 03:07 PM
fzn14's Avatar
And see its just not certian gears tho...Me and AJ are gonna data log it tonight and see what happens
Old Oct 22, 2008 | 03:24 PM
Area47's Avatar
Rent me! per hour
just for reference. my car shows 22+psi on the gauge. log's show 20-21 depending on air temps. im more inclined to believe the log than the autometer gauge.
Old Oct 22, 2008 | 03:28 PM
Witt's Avatar
Try disconnecting the vacuum reference line to the electronic bypass solenoid and plug it to see if it is leaking.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
