boost pressure drop!!!
Old Jul 14, 2008 | 10:32 PM
stern24's Avatar
hey ive been learning a lot from this sightSo i just bought an 07 SS, and all ive been reading is stock should be around 12 pounds. Well, when i got it it was only around 10. I got the gmpp catback, and stage 2 installed, and the first time i drove it I smiled as i watched the guage at 15psi, and ever since usually only see about12.5. Once in a while it quickly jumps to 14 for a split second near redline. Is there a problem here? The car is still quick, but i need it all so i can keep blowing by my buddies gti Ju.st would like to get some imput so i no wat im talking about if i take her back to the dealer. I love this site by the way.
Old Jul 14, 2008 | 10:39 PM
Bika's Avatar
Fail Less.
what elevation are you at? high elevation = less boost.
is your redline 7000? if not, they didnt reflash your ecu.
also, every car isnt going to see the same boost. an increase of 2.5 psi is expected from stage 2. its not unheard of for some cars to only boost 10 psi stock.
Old Jul 14, 2008 | 10:59 PM
stern24's Avatar
no high elevation, im in WI. i actually just took a test run and it was back up around 14, so ill just watch it the next few days.it was reflashed.thanks for the help though. Does your boost gauge set back to 0 when you turn your caroff?mine doesnt but if i turn the key on it does. ve just been checkn out everything, im picky bout my stuff cuz i like my car
it very wellcoulda been because ive got a set of floor mats over the stock ones and i couldnt get the pedal down all the way...and i race a thunderstock at my speedway every sunday...im a *******
Old Jul 14, 2008 | 11:25 PM
Bika's Avatar
Fail Less.
lolz. yeah pressin the pedal all the way down might get you a lil more power
no, the boost gauge does not go to zero when you shut the car off. it holds the last reading. it will zero out when the battery power is turned on again
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
