A/c Refill
A/c Refill
CAn some one post up a pic of where im so pose to refill the ac at... cause i bought a bottle of it and it wont fit around the black caped fitting on the ac line the fitting is bigger then the refill hose fitting not sure if it the low side spot tho. and i cant fine any other spot that looks like a refill spot.
ps..if you need a refill, you have a leak. hence a shop. if you over do it cuz the psi in the system is fine, youll blow the unit. I assume your ac is ither not working or not feeling cold, either way, a shop will be your best bet. You may just need a flush and new fridgerant. Adding that crap will do harm, not good.
Don't put these refill stuff in your a/c system. If you have a leak, it needs to be repair by technician and refilled with good r-134a. If you get any problems later, shops will detect the **** you put in and won't work on your car. Trust me I work in a dealership and it already happened.
The reason anyone can buy ac kits off the shelf is because it's not actually refrigerant, it will work in the system but it drys out o - rings and seals very fast, and over time you will have leaks everywhere, and as stated above most ac shops have identifiers (my shop) if we detect anything but r-134a we won't touch it because it will contaminate our machine.
FL@SH
Dec 30, 2005 08:00 PM
