cant seem to put car in reverse...
Old Apr 29, 2011 | 12:26 PM
shredout's Avatar
alright, a quick rundown of problems on car...
I have a bent clutch rod, which will be replaced this weekend with a zzp adjustable.
basicaly, the shifter gets "stuck" and won't click into reverse. all other gears are smooth, but reverse doesn't like me.... sometimes I can pump the clutch a few times and it will decide to go in. I do need a trany fluid change, I lost a bit of fluid swapping axels.
ideas?
Old Apr 29, 2011 | 11:30 PM
MyOtherSS's Avatar
try putting it in first then going into reverse, has worked for me when reverse is being stubborn but i also dont have any bent parts.
Old Apr 30, 2011 | 12:38 AM
shredout's Avatar
that's what I've been doing. its only been having trouble for about a week, and t its only been about 2 days where the first then reverse trick doesn't work. I bought a exedy clutch and pressure plate a while back. the pressure plate is way heavier, so I guess the stock clutch rod wasn't strong enough and bent.. not sure if that's the cause of the difficulty, but I'm hoping so...
Old May 3, 2011 | 12:59 PM
MyOtherSS's Avatar
If the clutch can't fully disengage because of the rod that's probably the issue.
Old May 3, 2011 | 01:02 PM
MyOtherSS's Avatar
Also reverse is a straight cut gear while the others are not. In my old cavalier I had to put it in first then first and sometimes start letting off the clutch before it would pop in.
Old May 3, 2011 | 01:06 PM
Take2-08LT's Avatar
Heres the fix:
Start Vehicle.
Put in Neutral
Release E-brake
Open Drivers Door
Place Left Foot on Ground
Push Like ************ in a rearward motion.
Reverse Fixed
Old May 4, 2011 | 07:54 AM
shredout's Avatar
Originally Posted by Take2-08LT
Heres the fix:
Start Vehicle.
Put in Neutral
Release E-brake
Open Drivers Door
Reverse Fixed
lol. ive used that a time or two.
Old May 4, 2011 | 08:01 AM
YelloEye's Avatar
Mine is occasionally difficult when cold, just gotta push it into 3rd or 4th before dropping it into reverse. If that doesn't work roll the car back a bit while holding it against the reverse gate lightly. It'll drop in eventually.
Old May 4, 2011 | 06:11 PM
shredout's Avatar
replaced clutch rod and it works like new now!!!
vjoel2011
Oct 2, 2015 12:11 PM
ashalle2
Sep 16, 2015 10:36 PM
Gugi96
Sep 15, 2015 12:24 AM
The Rookie24
Sep 14, 2015 07:03 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
