Car has problem starting
Old Jun 10, 2009 | 03:57 AM
Tmac01243's Avatar
well my car has a problem starting it takes a very long time to start its juss wont like turn over or sumthing. i started thinging maybe i need a new battery and spark plugs and stuff like that. also my car seems to start smelling like fuel alot. btw its a 2007 pontiac g5. if it is a electrical problem i have a 1200 watt amp 2 10 inch kicker comps, pioneer avh p-4000 2 tvs in the headrest and underglows as well as 2nd gen dual ccfl projectors
Old Jun 10, 2009 | 05:01 AM
Nighthawk243's Avatar
Take the battery in to autozone and have it checked. It may be on its way out. If you pull it out and notice it bulging or leaking, then you can skip the testing step.
Old Jun 10, 2009 | 06:21 AM
Tmac01243's Avatar
well i will have to try that then cuz it seems rather odd only when its a cold start and sumtime whens its hot so i dunno wat it is
Old Jun 10, 2009 | 06:24 AM
revolution607@yahoo.'s Avatar
im guessing its the battery...
Old Jun 10, 2009 | 08:14 AM
Coblasts's Avatar
If the car is turning over real slow when you try to start it or it doesnt tun over at all(you will hear a clicking noise) then the battery would be suspect.
If its turning over fine but not starting for a long time I would say the plug need tobe changed.
Old Jun 10, 2009 | 08:26 AM
kezia's Avatar
it could be an injector and/or regulator related problem if your smelling a lot of fuel. i know gm has had a few problems with them leaking and causing a long crank issue.
F
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
ATOMbomb
Sep 11, 2015 10:48 AM
Jacque8080
Sep 9, 2015 09:21 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
