Car pops and jerks when I let off the gas
Old May 19, 2016 | 01:37 AM
Dougsterbob's Avatar
Im not sure what is going on here. But if I'm just rolling along in gear and I let my foot off the gas completely the steering wheel will twitch, the front end makes a pop and the car kinda jerks and then slows like I was pressing the break.
When I let off the gas to shift up this doesn't happen though, I'm assuming because I have the clutch pressed in. I'm hoping someone more mechanically inclined can tell me what this is because I have no clue.
I'm not positive but I think this has been worse since I had to drive a few hundred miles on a spare that was slightly bigger then my other front tire, so I was thinking maybe differential? Or axel? Is there a way to rule those out for sure?
Thanks in advance!
Old May 19, 2016 | 11:41 AM
ItalianJoe1's Avatar
If it happened after the spare tire, yeah you probably damaged your transmission. There's a reason they say only 50 miles on the spare, it's not because the tire will explode.
Old May 19, 2016 | 11:44 AM
This. Another reason why you never put a half spare on a drive tire or a not equally sized tire full spare.
Old May 19, 2016 | 11:59 AM
slapbetcommissioner's Avatar
Proper way is to put spare on the back and transfer the real tire to the front.
Old May 19, 2016 | 12:21 PM
So the only way to know for sure would be a tranny swap? Is there other things I should check first?
Old May 19, 2016 | 03:24 PM
You could try to feel how the diff is, by spinning the wheels by hand. But the forces involved when driving are so much higher that you may not notice it with no load on it.
Check your control arm bushings also. They can cause similar issues.
Old May 19, 2016 | 09:51 PM
Sl0wbaltSS's Avatar
If this is on a SS/TC the spare won't fit under the brembos.
Old May 19, 2016 | 09:54 PM
If this is on a SS/TC the spare won't fut under the brembos.
Thank you for the extremely relevant post.
Old May 20, 2016 | 12:14 AM
Sl0wbaltSS's Avatar
Thumbs up
Yay someone that doesn't hate me for crappy posts on here!
yellow_cobalt
Feb 17, 2022 11:33 PM
klotzy_550
Sep 14, 2016 04:25 PM
Herreric
Wheels and Tires
Apr 12, 2016 01:15 PM
Raptorunbound
Mar 17, 2016 12:10 PM
zerosk8ter83
Mar 11, 2016 03:08 PM
