Car shut off while driving
Might have had a similar issue... one night was cruising 45-50ish cruise was ON and then the car stated to sputter like it wasn't getting either gas/air car was under 1/4. I would try to give it gas and nothing would happen. I coasted into a neighborhood where it idled terribly so i turned it off sat for about a min with it completely off. I tried to start it and nothing wouldn't turn over. Got towed home it sat over night and i tried to start it one more time and it turned right over with no problem.
I've never had the issue since. Also sometimes after i turn corners the car sputters REALLY bad..
any idea?
sorry if this thread jacks.... issues are related imo
any idea?
No problem. I did some research and came across some good info https://www.cobaltss.net/forums/prob...o-start-54807/
Professionally speaking you have multiple issues Going on here.
I've done crank sensors on these ss/sc for nearly the exact shut off scenario. If the PCM detects an incorrect number of pulses from the CKP sensor, DTC P0335 sets. So be sure to check/clean all mating surfaces for sensor. if possible check the reluctor wheel for any signs of damage and also check for any build-up on ckp sensor itself.
The other code p0461 is usually due to the lever sender contacts are becoming worn and not returning the proper resistance to the ipc.
So basically I need to go ahead and replace the crankshaft sensor since Ive bought a new one already?
if surface is already bare metal obviously there is no need to clean.
brickloaf
Sep 6, 2015 05:55 PM
