Car stuck after sitting overnight
Old 12-24-2013, 10:18 AM
Nichq's Avatar
The past couple days when I start up the car I gotta give it some gas to get it to move and break loose. Seems like its stuck or something and wont move and then I give it a bit of gas and itll pop and start moving freely. Happens when I first try to use it in the morning, and then when im leaving for work at the end of day. I dont use the ebrake, just keep it in first when I park it. Brakes dont seem to be locked up. Its almost like wheels are just jammed and then I give it a tiny bit of gas and it breaks loose and everything is fine.
Old 12-24-2013, 10:19 AM
blueLNFftw's Avatar
park in nuetral and use the hand brake.
see if it still doe sit.
Old 12-24-2013, 10:30 AM
Nichq's Avatar
I would try that except my ebrake cable kep popping off cause the cable is stretched out. Wont hold the car if its on on decent inclines anymore, so I dont trust it. Hence i've been putting it in gear for the past few months.
Old 12-24-2013, 10:41 AM
blueLNFftw's Avatar
Zip tie it into the hold in the center console.
Old 12-24-2013, 10:52 AM
Nichq's Avatar
Yea, the auto shop did that when I last took it there. Cable it just too stretched out though. Gotta yank the brake up as far as humanly possible now a days to get it to fully hold the car. So i dont even bother, just keep it in gear. Getting rid of the car in April.
Old 12-24-2013, 10:57 AM
blueLNFftw's Avatar
Adjust the cable then.
IDK what else to tell you.
Only way to determine if it is the trans itself you are against.
Good luck sir.
Old 12-24-2013, 11:00 AM
heeter_33's Avatar
Sounds like its frozen to the ground but I don't know if its cold enough there for that? Happens to me all the time here.
Old 12-24-2013, 11:04 AM
yellowsupercharged06's Avatar
i was thinking the same thing but its not even that cold in this area
Old 12-24-2013, 11:13 AM
Nichq's Avatar
Yea, was thinking that also but it was unussually warm yesterday, 68 degrees. So doubt that was it.
At work now so I tried parking the opposite direction I normally do and then putting it into reverse instead of first. I'll see how it is when I go to lunch in a few hours.
Old 12-24-2013, 11:32 AM
i mean this is just my opinion buttt...... your letting your car sit on an incline locked into gear ?
that dont sound too transmission friendly to me ... i mean its used as a precautionary measure if your ebrake fails but to let it sit there all day with all the stress on the gear ...
Old 12-24-2013, 11:38 AM
Nichq's Avatar
Its not really on that much of an incline, almost a flat surface in the parking lot. However I always read people here who say they never used there ebrake and just put it into gear.
Old 12-24-2013, 12:41 PM
I use my ebrake
Old 12-24-2013, 01:45 PM
BlackielawlessSS's Avatar
I have never used my e brake on anything unless I was on an incline.
Old 12-24-2013, 01:47 PM
cluelessk's Avatar
It's frozen to the ground.
Just turn your wheels left to right before trying to drive.
Old 12-24-2013, 02:44 PM
tomj77's Avatar
my car does the same, even with no ebrake, if its stormy and snow blows onto brakes after uv used them it freezes them, easy fix if u cant get it going, get a pail of hot water and throw it on the brakes. then get in and drive and brake till they are dry. that's what I had to do no to long ago
chefhhr
10-26-2015 10:36 PM
How to Guide
57
10-15-2015 11:56 AM
hawkssoccer11
09-30-2015 12:14 PM
Dope_SS
09-13-2015 05:24 PM
Quick Reply: Car stuck after sitting overnight
