Car stumbles and bucks when A/C is on. SES light?
Old Jul 2, 2015 | 03:21 PM
Hawk312's Avatar
My 2009 Cobalt is bucking and playing games on acceleration, but only when the a/c or windshield defroster is on. Otherwise, it purs like a kitten. Before turning my A/C on back when the weather was cooler, I had no SES light, but now it is on. No strange sounds or anything like that. I have already cleaned the throttle body. Thoughts?
Old Jul 2, 2015 | 04:15 PM
What codes?
Old Jul 2, 2015 | 04:23 PM
umrdyldo's Avatar
SS or non SS.
If it's a non SS car I would check all of your vacuum hoses. Check your intake for air leak.
Old Jul 2, 2015 | 04:38 PM
Hawk312's Avatar
Thanks guys. Non-SS and codes are for incoming air temp and maf sensors. All connections seem fine and it is strange it is only when AC is on. 5 speed also.
Old Jul 2, 2015 | 04:43 PM
LNFTX's Avatar
I thought this was normal my car is a pita when the ac is on. I always attributed it to the extra drag of the ac compressor causing the rpms to fall unnaturally fast but ive never had a code
Old Jul 2, 2015 | 04:49 PM
Try cleaning the maf. I'd guess your ecu is seeing different things when the load of the AC kicks on and it bouncing between tables
Old Jul 2, 2015 | 04:57 PM
Hawk312's Avatar
Thanks guys. What is safe to use when cleaning these things? Is the iat part of the maf?
Thanks!
Old Jul 2, 2015 | 05:02 PM
umrdyldo's Avatar
Thanks!
Amazon.com: CRC 05110 Mass Air Flow Sensor Cleaner - 11 Wt Oz.: Automotive Amazon.com: CRC 05110 Mass Air Flow Sensor Cleaner - 11 Wt Oz.: Automotive
Just read the instructions. Should be able to buy just about anywhere. Works really well from what I have seen.
Old Jul 2, 2015 | 05:05 PM
Dipped_Cobalt's Avatar
are you putting the ac on high?
I would clean the sensors and verify all vacuums are still connected correctly
Old Jul 3, 2015 | 01:51 PM
Hawk312's Avatar
No luck with the cleaner. All connections look good. Looks like it is a new maf sensor for me. Given both the IAT and the MAF are the same unit, and they are both throwing codes, I would think that is a pretty good indication I need a new one? It definitely has a misfire or something...I can here it in the exhaust from the back.
Old Jul 4, 2015 | 01:02 PM
Hawk312's Avatar
New MAF seems to have fixed the problem. SES light went off after the first start. $60 and about 5 minutes to replace.
Old Jul 4, 2015 | 01:28 PM
ItalianJoe1's Avatar
Glad you got it fixed.
Definitely on newer MAF cars where the IAT is integrated and you see IAT/MAF codes all setting with drivability issues, there's something going on with the sensor.
The one you removed, you said it looked recently replaced, was it an aftermarket one? The non-OEM ones just don't work as well or last as long. They are cheaper but you pay the price on longevity.
Old Jul 4, 2015 | 01:34 PM
chris88z24's Avatar
Rule of thumb is to always go OEM unless there's an aftermarket part that's proven to be better (like Powell CAB's).
Meadowvalien
Aug 17, 2017 06:32 PM
How to Guide
57
Oct 15, 2015 11:56 AM
ATOMbomb
Sep 11, 2015 10:48 AM
jthwjde
Sep 7, 2015 09:24 AM
