Car will not start.
Old Sep 20, 2018 | 11:02 PM
T28eclipsegst's Avatar
Car will not start.
So i go to leave work today and my car decided to not start. It has power to half of everything even the fuel pump, but the trunk and turn signals do not work and the car wont try to start. When i turn the key over i can here the relay clicking but its not trying to turn over at all. Mydometer reads my miles for a couple seconds then just has a line across the panel and wont pull no readings. The car doesnt have no security light poping up and no codes on my scanner. I unhooked the battery for awhile but nothing. This just happend out of the blue. Any tips on some what of a direction i can look twards would be apriciated
Old Sep 21, 2018 | 10:45 AM
royce777's Avatar
dead battery
Old Sep 21, 2018 | 12:41 PM
Flarfignewton's Avatar
Yep, I would go with dead battery too.
Old Sep 21, 2018 | 05:09 PM
Ok ill test it or get a new one and post later on, thank you, any tips is better then none.
Old Sep 28, 2018 | 11:21 PM
Just a late notice the problem turned out to be the bcm and battery was ok. Thanks again
Old Sep 29, 2018 | 09:30 AM
Kolt's Avatar
Did you check the main fuse by the battery? It powers nearly everything on the bcm, also runs the power for the ecm/pcm. Make sure it isn't burnt or anything. Have been seeing more and more of those lately.
Boxxy
Sep 10, 2011 11:18 AM
Highbeamz
Dec 9, 2009 12:03 AM
pecowill
Sep 7, 2009 08:24 PM
zzzzzzzz
Sep 30, 2008 08:26 AM
neb07ss/sc
Jul 31, 2007 10:54 PM
