Catastrophic Supercharger Failure
Old Jul 12, 2013 | 10:30 PM
chris88z24's Avatar
As mentioned previously, I have been dealing with weird noises and low boost coming from my SS S/C, in addition to a rough idle, for probably over 2 years now. Today the supercharger completely failed. The pulley sheared off from the hub with the screws still attached. I was driving and heard a loud clanking sound. Then all of a sudden there wasn't any boost. The battery light also came on. The pulley was lying in the corner of the engine bay and the belt obviously wasn't spinning. Ended up limping the thing about 8 miles (in the dark) to get home.
So for those of you with superchargers making strange noises or if you're having low boost issues - fix it now before the heaton self destructs like mine did.
Old Jul 12, 2013 | 10:54 PM
Gunney_07's Avatar
Now its a question of TVS or turbo
Old Jul 12, 2013 | 11:21 PM
chris88z24's Avatar
More like find a stock M62 for as little $ as possible. lol
Old Jul 12, 2013 | 11:23 PM
BoSStwick's Avatar
By chance do you have a video of the sound your Cobalt was making before it self-destructed? This could be a great tool for people to use.
Old Jul 12, 2013 | 11:27 PM
chris88z24's Avatar
Nope. It just felt really sluggish and it would always hesitate under 4000rpm or so. It made a bunch of hissing/grinding noises when you pressed the gas. Right before it failed, when I started it up, it made the worst rattling sound I've ever heard. Then it kept squeaking and rattling until finally the whole thing destroyed itself.
Sucks, these things aren't cheap either. Only had a 3" pulley on it as well.
Old Jul 12, 2013 | 11:38 PM
chris88z24's Avatar
What's strange is that the hub is still attached to the snout, and I can spin it by hand. The only problem is that it's about 2" away from where it's supposed to be.
Junk.
Old Jul 12, 2013 | 11:44 PM
ThexGovenor's Avatar
I might have a m62 with a 2.8 for sale soon. if you need it.
Old Jul 12, 2013 | 11:45 PM
BoSStwick's Avatar
Damn, that really sucks. New Eaton's are like 600 bucks, and a used one probably goes for about half that. Do you think you could salvage some of the parts in the supercharger and kind of "make your own" by combining other salvage parts?
Old Jul 13, 2013 | 12:24 AM
chris88z24's Avatar
Cheapest I found new was 799 on ZZP website. I might be able to rebuild it, but I won't know what went wrong until I take it apart and see what failed.
Old Jul 13, 2013 | 01:27 AM
OttawaMark's Avatar
As low as $200 on this site, just keep your eyes peeled. Check RL forums as well.
Old Jul 14, 2013 | 04:30 PM
chris88z24's Avatar
Found a used one on e-bay with a stock pulley.
Old Jul 14, 2013 | 06:54 PM
Yea i was gonna say they go for cheap on ebay
Old Jul 14, 2013 | 07:25 PM
ItalianJoe1's Avatar
Sounds like it broke the drive shaft off inside. Interested to see what the rotors looked like. Be sure you get any pieces of metal out of the intake manifold, or you will ruin the replacement blower very quickly.
Old Jul 14, 2013 | 07:26 PM
Glad I don't have a supercharger to worry about failing.
Old Jul 14, 2013 | 09:13 PM
chris88z24's Avatar
I'll disassemble it tomorrow and post the carnage. The rotors were scuffed when I removed the blower at like 35-40k. The fact that it lasted another 46k is pretty amazing now that I think of it, lol.
Old Jul 15, 2013 | 07:32 AM
Staged07SS's Avatar
Administrator
Administrator
Why did you wait so long to check what was wrong with it man?
If my car ever makes even the slightest weird noise, I search for the issue before I drive her again.
Old Jul 15, 2013 | 09:33 AM
chris88z24's Avatar
Always thought the hissing was some sort of small exhaust leak. It only happened under boost.
Oh well. New blower ftw!
Old Jul 15, 2013 | 10:20 AM
Staged07SS's Avatar
Administrator
Administrator
I get ya. At least nothing else happened.
You need to take some photos of the carnage.
Old Jul 15, 2013 | 11:40 AM
Hockeyman's Avatar
Had you ever changed the SC oil? How many miles were on it?
Old Jul 15, 2013 | 11:53 AM
ebristol's Avatar
This thread is worthless without pics.
Old Jul 15, 2013 | 12:10 PM
SalvageBaltSS's Avatar
yes, pics are a need lol
Old Jul 16, 2013 | 01:12 PM
chris88z24's Avatar
I can't figure out what the hell happened. The rotors turn freely with the hub, and those scuffs that are on the rotors were there 40k ago. There's no play in the shaft either! Everything looks the same as it did 40k ago except for the pulley that somehow sheared off from the hub.
Can you guys spot anything odd?
Old Jul 16, 2013 | 01:19 PM
Staged07SS's Avatar
Administrator
Administrator
I can't figure out what the hell happened. The rotors turn freely with the hub, and those scuffs that are on the rotors were there 40k ago. Everything looks the same as it did years ago except for the pulley that somehow sheared off from the hub.
Did you have the pulley bolts torqued to spec? (16 ft-lbs)
Also, was the pulley hub installed flush and straight??
::Edit:: Pictures were not showing when I first commented.
What pulley sytem is that?? Smoothflow or ZZP? The hub looks like it was installed backwards, or the snout shaft is f'd.
Those marks in the rotor coating are an indicator of rotor to rotor contact for sure.
Old Jul 16, 2013 | 01:22 PM
Spawne32's Avatar
your belt was probably over tightened by ALOT, that would cause the bearings to fail in the snout, but ive never heard of one sheering off the hub before
Old Jul 16, 2013 | 01:23 PM
chris88z24's Avatar
Smoothflow.
If it was installed backwards that would explain the carnage.
Belt's fine.
