Clogged Cat or Cam Timing
Old Jan 31, 2009 | 10:28 PM
El Mariachi's Avatar
In Brief:
I had bent some valves and had the head fixed, compression tested 100%.
I recently got the car back and heres the problem:
When I accelerate, the car runs fine and completely normal under 3 rpms, I can even go higher all the way up to 6 or 7 if i lightly tap on the accelerator. But when I spool or casually go over 3 rpms, the car gets all hesitated and restricted to gain rpms or speed. It will slowly try to gain speed and i get like a pulling back kind of feel. Whats everyones say on this...
is the timing off or the cat clogged
bumpity bump
Last edited by El Mariachi; Jan 31, 2009 at 10:28 PM. Reason: Automerged Doublepost
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
