Cobalt pulls to the drivers side
Old Nov 29, 2011 | 09:17 AM
crazydude's Avatar
Question Cobalt pulls to the drivers side
my 09,auto, 2.2l, aprox 20k miles cobalt pulls to the drivers side.
I can only assume it is a wheel alignment issue...unless anyone can suggest a common problem to check for? My warranty is up... so I wanna ensure I check things first to avoid getting muliple alignments.
Do our cars need 4 wheel alignment? or strictly a front alignment???
Old Nov 29, 2011 | 09:21 AM
emiller's Avatar
Check your tire pressure and for a stuck brake. Both cost nothing and are easy.
Old Nov 29, 2011 | 01:41 PM
Chevrolet Cust Svc's Avatar
I see you've gotten great feedback from emiller already. If you need assistance in working with a dealership in the future, please get in touch with me via private message.
Best,
Sarah
GM Customer Service
Old Nov 29, 2011 | 07:44 PM
MyOtherSS's Avatar
Front only, the rear is non-adjustable. You should only need to get it aligned once and if it pulls after that you have another issue.
Old Nov 29, 2011 | 09:23 PM
crazydude's Avatar
Tire pressure is bang on even all the way around. The brakes look fine
I guess I will shell out 80 bucks an get an alignment (expensive in canada)... I hope it fixes it.
Old Dec 1, 2011 | 02:04 AM
robertmichaels's Avatar
sub'd
sry for the thread jack, but...
i have kinda the same thing...it started after my engine swap, this doesnt happen all the time, just once in a while...when it does happen most of the time it pulls to the drivers side, and like 10% of the time it pulls to a side its the passenger, it goes away after a minute or 2...anyone have an idea??
not lowered
Old Dec 1, 2011 | 02:33 AM
bratboy90's Avatar
You weight 300 pounds bro? Might wanna lay off the cheezburgers JK
Mine pulls whichever way it ****** wants on Minnesota's shity crooked roads that are tilted at 20degrees half the time. I also am extremely lowered.
Old Dec 2, 2011 | 08:15 PM
Phil424's Avatar
All i can add in is make sure when you are doing these tests for alignment that the road is exactly straight. When driving on most highways and you are in the left lane you get a pull to the left a lot. Be exactly sure that you do need an alignment. Alignment angles for the cobalt are toe and camber, but to adjust camber you need a special bolt for the strut, it's really not needed to adjust it unless it is completely off and is causing un even tire wear. Set the toe and let it go.
Old Dec 5, 2011 | 01:32 PM
Ownedbyagirl?'s Avatar
49.99 to get the front end inspected at the chevy dealership!
Old Dec 5, 2011 | 09:42 PM
metzO7's Avatar
rear toe and camber is adjustable with full contact shims know this for a fact on my 06 ss sc as I'm an alignment tech
robertmichaels Sounds like you have too little caster which allows the car to "follow" the ruts in the road as for the OP sounds like your camber is off to much negative on the passenger side or to much positive on the driver side remember camber pulls to the higher side caster pulls to the lower side on my local roads I need aprox .5 degrees pulling to the left to go straight but will vary with road crown
Old Dec 5, 2011 | 09:46 PM
metzO7's Avatar
also many places do free alignment checks where I work does great for customers like you
Sean Cummings
Jan 8, 2020 10:17 AM
Turbo Johnny
Feb 21, 2019 09:41 AM
brickloaf
Sep 25, 2015 09:10 PM
Jacque8080
Sep 9, 2015 09:21 PM
