Cobolt SS Supercharged Idle
Old Oct 26, 2005 | 04:02 PM
Dist's Avatar
I just picked up my '06 SS Supercharged, The car is a blast
One problem though, when I come stop, sometimes the idle will go from 500rpm to 1200, in a loop for about 5 seconds. If I let it sit, or hit the gas, the idle will drop down to 700rpm and everything is good.
Anybody else have this problem?
Thanks,
Old Oct 26, 2005 | 04:10 PM
c7015's Avatar
Lots of people (not me) but I dont think its anything to be too concerned ...next time you are in at the dealer see if they can do something about it ...usually there is a ISC (idle control screw) that you can adjust with a coin to fix it
Old Oct 26, 2005 | 04:13 PM
MarcS's Avatar
The Stig
There is a TSB on cold start idle quality.
Your dealership can do a reflash to fix the issue.
Old Oct 26, 2005 | 04:40 PM
Dist's Avatar
Thanks for the info guys, I did call the dealer about it, I'll let them take a look at when I take it in for it's first service.
Old Oct 26, 2005 | 04:53 PM
p7x's Avatar
p7x
How many miles / kms on your SS mine did it around 6000 kms and i only did it a couple times and it hasnt happened since im at 13000 kms.
Old Oct 26, 2005 | 05:58 PM
Dist's Avatar
It's brand new, currently has 550 miles on it. It's done it since I got it.
Old Oct 26, 2005 | 06:02 PM
p7x's Avatar
p7x
if it persists take it in
Old Oct 27, 2005 | 10:31 PM
PackAttack85's Avatar
The cobalt and every car out is computerized. This means that there is no adjustment screw for idle. You must be a backyard repairman with a $300 golden frinking screwdriver!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!
Old Oct 27, 2005 | 10:42 PM
Cobalt_Supercharged's Avatar
I noticed it mainly with the engaging and disengaging ot the A/C compressor.
Old Oct 27, 2005 | 11:28 PM
ExHondaMan's Avatar
Domestics Pwn
Mine did it when it was new... After a little bit it just stopped... seemed related to AC compressor being engaged. I would get your PCM flashed if you can anyways though... couldnt hurt anything.
Old Oct 27, 2005 | 11:33 PM
Mine hasn't done it as often as when I first got it. Matter of fact it hasn't done it in a while. (knock on wood)
Old Nov 2, 2005 | 03:13 PM
Blowit's Avatar
Same problem
Just picked up my SS/SC, and have experienced the same issue.
It happens when the car is warm, that's the only thing consistent I have found so far. My car had 18miles when I picked it up.
Last couple of of times, I muted the radio and the idle came back, could be a fluke however.
I hate dealership garages, so I'm hoping it will go away.
Old Nov 2, 2005 | 10:26 PM
I think it was a coincidence (however you spell that). It should become less and less common. I think it is a matter of the computer learning it's calibrations. Mine became less frequent the more I drove it.
Old Nov 8, 2005 | 09:32 AM
Dist's Avatar
It does become much less frequent. My SS SC hasn't done it for about a week now.
Old Nov 8, 2005 | 09:41 AM
Chevypowered's Avatar
It seems to do it if you rev it up or are driving and have the clutch in between gears for a period of time. when stopped and rev it up it might be there to insure all the fuel was burned are it was reved up??? maybe just a guess. I dunno about the in between gears time.
Old Nov 8, 2005 | 09:55 AM
memphisr24's Avatar
Mine has the weird idel too. I think it's normal.
Old Nov 14, 2005 | 02:56 AM
ss_mike's Avatar
there is a idle reprogram for the cumputer cuz theres no idle screws since the car has no throttle cables. happen with mine and i just went into work and reprogamed the cuputer with the updated flash for the computer all is know good
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
