cold air problems
cold air problems
i just added a cold air made with a k&n filter. On my first test drive i noticed that we started to bog out (really bad) at around the 4000 RPM range. I have the stage 2 from GM installed but I DO NOT have colder plugs yet could this be my problem i also do not have any codes reading.
Thanks I will give that a shot
ok so unplugging the battery didnt work and now i cant get past 4500rpm in all gears any suggestions
it was unplug for 1/2 hour still not running good i am also getting a funny smell something i have never smelled before if i was running to rich or to lean would i get any codes.
If I understand correctly..... and I seldom do.... but I believe if you touched the MAF it could be giving you fals readings... the MAF is a tuchy little bugger and the oils off your skill could confuse it a bit
iam still lost on this problem
i just some of my own tests and i learned iam burning 34.5L/100km which is way high and if the car is cold it runs nice untill it warms up alittle.
Remember that the cold air filters carry in the element a small amount of oil , sometimes too much is put on at the factory and the excess oil gets sucked out into the air way which comes into contact with the air flow sensor throwing it off and causing over-fueling ..... you should "at the worst" get 12.8/100km and that shuold only be in the winter when it's realy cold.... try spraying some carb cleaner at the element but not too much...then again? I'm not sure if that might be too harsh....find out first from a qualified mechanic... but any which way I thing that sensor is contaminated.
roth
Sep 26, 2015 12:16 PM
OrangeCoba
Sep 25, 2015 06:06 PM
