Coolant recovery pipe - hole formed,
Old Apr 17, 2015 | 10:23 PM
Paprika's Avatar
Exclamation Coolant recovery pipe - hole formed,
2009 Cobalt 2.2L
Anyone know why this coolant recovery line includes a metal segment in the middle?
My pipe mysterious grew a hole, leaked coolant for hours (or even days) and the car started to overheat on the expressway. Found it and put in a temporary measure to close the leak. But now I need to refill the system and I'm trying to figure out why I shouldn't replace the entire line with a single rubber hose, which would cost less for a quality hose (<$5) than buying a replacement OEM part ($40).
Image credit to WhiteSSBalt (C) 2008. Using just for quick discussion reference.
Old Apr 17, 2015 | 10:43 PM
Superbolt's Avatar
That sucks I would replace it with the oem hose imo...
Old Apr 17, 2015 | 10:45 PM
Yup i agree with superbolt it may have to be due to heat thats why its not all rubber but i could be wrong
Old Apr 17, 2015 | 10:46 PM
Superbolt's Avatar
Ya could of just been a faulty part from factory.
Old Apr 17, 2015 | 11:29 PM
LTBALTBMX's Avatar
If you're cheap, you could probably plug it up with some solder or brazing.
I don't see anything wrong with a rubber hose though. Its not like they use the metal section to wick away heat.
Old Apr 18, 2015 | 07:20 PM
ItalianJoe1's Avatar
The metal was probably done due to a rubber hose wearing through on the other parts in the area. There should be plenty of those metal lines available used, I could look and see if I have one, i'm sure I do.
But a rubber hose would work just fine from a function point, just make sure it's not rubbing on anything.
Old Apr 18, 2015 | 07:37 PM
LTBALTBMX's Avatar
1 more thought on replacing the metal pipe. Be wary of the metal you choose otherwise you'll end up with a galvanic corrosion problem.
Old Apr 19, 2015 | 01:28 PM
Paprika's Avatar
Exclamation
Ditto. That is why I do not want to replace it with just any metal pipe. If I want to replace it with metal I'll just buy a new OEM replacement.
But used works also! Anyone have a used one for sale LMK.
Thank you all for the strong responses.
Old Apr 19, 2015 | 01:46 PM
Why not go to a salvage/wreaker yard and get one?
Old May 28, 2019 | 05:21 PM
Mike Labanowsky's Avatar
Excellent work
Excellent investigation. Just finished fix. Used 2” high temp/high pressure tubing, and 2 hose clamps. Guided metal portion away from air intake cover. Reservoir tank now releasing pressure, sure missed hearing pressure relief when removing cap. Car not heating up to 215F+ when first starting, idling at 185F now.
Great writeup and excellent investigation! Would love to help if you ever hit another roadblock.
NickD
24
Nov 3, 2014 12:02 PM
seeyaass
51
Sep 10, 2011 10:27 AM
pickin my brother up
Nov 5, 2009 08:34 PM
hallss
Aug 7, 2009 01:57 AM
BaltSS
Mar 16, 2008 05:29 PM
