Cracked engine mount
Old Aug 29, 2006 | 04:01 PM
Halfcent's Avatar
I'm old school
So here's one I haven't seen yet. I was doing some routine cleaning under the hood today and took off the air box to check the air filter. While I was there, I saw a little something out of the corner off my eye...
It's actually cracked on both sides. My crappy cell phone camera didn't show it very well, but its identical from the holes outward to the edge. Guess I'm off to the shop for a warranty repair!
Old Aug 29, 2006 | 04:04 PM
3fo893013L's Avatar
That's too bad. Something must be giving it some extra added vibration.
Old Aug 29, 2006 | 04:05 PM
g5mike's Avatar
Originally Posted by Halfcent
So here's one I have seen yet. I was doing some routine cleaning under the hood today and took off the air box to check the air filter. While I was there, I saw a little something out of the corner off my eye...
Well we will have to add you to the list now,I expected this on the 2.0 with all its torque but not the 2.2 now Im goin to have to go check mine.
Old Aug 29, 2006 | 04:08 PM
CTCOBALTSSS's Avatar
Hmmm. I guess I should check mine too. That sucks bro. I don't get it. There are SS/SC's with Ingalls torque braces that are just fine........
Old Aug 30, 2006 | 12:32 AM
rnjmur's Avatar
The ingalls would probably help provent this, since the dampner is actually taking stress OFF the mount.
Old Aug 30, 2006 | 12:43 AM
mi6_'s Avatar
It is probably a defect in the engine mount. Probably not something the rest of you should worry about.
Old Aug 30, 2006 | 05:18 PM
Halfcent's Avatar
I'm old school
Got it replaced today. They used a completely new mount design, including the bracket attached to the engine. It now has the same geometery as the LSJ mount (so now the Ingalls torque dampner should fit) and the frame side part of the mount has additional casting bosses right in the location where my old one cracked. You can also now get to the timing chain guide nut without using the cut-off allen wrench. I'm actually really happy with it. And under warranty!
Old Aug 30, 2006 | 05:26 PM
JRANGER's Avatar
im going to check mine. Half the time when i stop i start hearing the engine. Like it starts rattling the crap out of stuff under the hood. I dunno if it jsut the engine cover is loose or its rattling the hood but im going to look at that mount and see if i can notice anything else on my 2.2
Old Aug 30, 2006 | 05:31 PM
HackAbuse's Avatar
Thats really wierd, you have reduced compression, and an automatic, and i know you dont really beat on your car
Thats a big defect.
On a side note, I broke my second wheel stud last week. Has anyone elses wheel studs been breaking off?
Old Sep 1, 2006 | 05:24 AM
redlineblueline's Avatar
The studs themselves are like 2 or 3$ from Firestone or somewhere like that. Mine looks like the different alloys in the mount are starting to flake apart, the best way to describe it is it looks like a puzzle I'm worried it will crack through all of these line.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
