crankshaft position sensor
Old Aug 4, 2012 | 02:09 PM
ginger's Avatar
where is the crankshaft position sensor located on the LNF?
Old Aug 4, 2012 | 02:28 PM
Coblasts's Avatar
At the back of the engine above the Starter on a 06 SS SC ,should be the same for your car.
Old Aug 4, 2012 | 06:33 PM
ginger's Avatar
is it easily accessible? or will i have to remove anything to get to it?
Old Aug 4, 2012 | 06:36 PM
BankerBalt's Avatar
you might have to remove the starter. i have to replace mine too ha
Old Aug 4, 2012 | 06:56 PM
ginger's Avatar
how is your car acting? when i drive mine it wont rev past 3K without it boggin down so i cant push it hard at all and im throwin a P0336 and P0338 code.
Old Aug 4, 2012 | 07:00 PM
BankerBalt's Avatar
i get a p0300 all the time. random misfire i'm assuming is that. when i was tuning it, most of the time at idle it just stopped reading rpms, went from 800 - 0 with no in between. car likes to lobe at idle. i've kinda had the problem since before the car blew, so that's the problem i've been assuming. i also can't go into more than a couple pounds of boost and i can't tell if that's the tune or the sensor but i'm still in my break in period
Old Aug 4, 2012 | 08:56 PM
ginger's Avatar
i have a P0300 always showin to. and yes it is a random misfire. you have any idea what causes that? other than the P0336 code, my car runs just fine. i get full boost and everything with no problems until this code showed up the other day after it wouldnt go past 3,000 rpm's
Old Aug 4, 2012 | 09:13 PM
Coblasts's Avatar
If you change the crank sensor you will have to get a relearn done at the dealer.
Maybe it can be done with hp tuner but I'm not sure.
Old Aug 4, 2012 | 09:33 PM
ginger's Avatar
you think maybe i could just use my trifecta cable and flash the tune back onto it?
Old Aug 4, 2012 | 11:28 PM
Coblasts's Avatar
Know nothing of that,maybe someone else can chime in with some exrtra knowledge on that.
Old Nov 11, 2012 | 11:17 PM
ltr450racer690's Avatar
not tring to bring a dead thread back up. but i did mine today, can do it without taking anything off if you have small hands and take your time. havent popped a code up today and ran much better. we will see
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
cw383
Sep 30, 2015 12:41 AM
jmelton327
Sep 26, 2015 10:04 PM
