Crap load of codes, o2 sensor issues?
Any ideas guys? Don't see any noticeable performance issues other than it cuts off AFR gauge on RPD making it display "No Data Available"
More than likely it is an O2 problem.
You need to verify the wiring for the sensors before you condemn the sensors.
If you have the abitity to watch the O2 milivolts, stick a Tpin in the sensor wires(not the heater circuit side), lick your fingers, and touch one finger on the Tpin and the other finger on the positive batt terminal, then the negative.
If you do it right, you should see the millivolts go max then min.
That verifys the wiring. Your body is almost the perfect resistance to verify the wiring accurately
If that trick works; replace O2s
Sl0wbaltSS
Nov 21, 2018 11:11 PM
