Crap load of codes, o2 sensor issues?
Old Feb 17, 2013 | 09:13 PM
Aleksey's Avatar
Any ideas guys? Don't see any noticeable performance issues other than it cuts off AFR gauge on RPD making it display "No Data Available"
Old Feb 19, 2013 | 01:02 AM
Aleksey's Avatar
Okay come on guys not all at once
Old Feb 22, 2013 | 03:36 AM
Aleksey's Avatar
All this help, what would I do without it
Old Feb 22, 2013 | 06:58 AM
BLKLS's Avatar
Fuse, a lot of times both sensors run off the same fuse. Try that and trace the harness make sure it's not eatin or melted.
Old Feb 22, 2013 | 08:05 AM
turbosmart4's Avatar
Dibs on 2 tc rims
Jk
Old Feb 22, 2013 | 05:45 PM
Speed_Thrills's Avatar
IT's gotta be an 02 sensor problem. The one on the manifold I'm guessing
Old Feb 22, 2013 | 07:02 PM
Aleksey's Avatar
Threw a couple more codes today,
P0140
P0141
Got to be kidding me I drive the car twice a month due to weather and it manages to break without me even using it
Old Feb 22, 2013 | 07:14 PM
Verbatim's Avatar
More than likely it is an O2 problem.
You need to verify the wiring for the sensors before you condemn the sensors.
If you have the abitity to watch the O2 milivolts, stick a Tpin in the sensor wires(not the heater circuit side), lick your fingers, and touch one finger on the Tpin and the other finger on the positive batt terminal, then the negative.
If you do it right, you should see the millivolts go max then min.
That verifys the wiring. Your body is almost the perfect resistance to verify the wiring accurately
If that trick works; replace O2s
Old Feb 22, 2013 | 10:01 PM
BLKLS's Avatar
I highly doubt both O2 sensors would go at the same time. Very unlikely. You said you don't drive it much, check the wiring, check the fuses. Did you tune it and just go wicked lean?
Old Feb 23, 2013 | 02:31 AM
Aleksey's Avatar
stock tune
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
tomj77
Oct 4, 2015 11:39 AM
jmelton327
Sep 26, 2015 10:04 PM
