CV boot replacement?
Old Dec 5, 2007 | 01:01 PM
YelloEye's Avatar
Does anybody know if a CV boot from a cavy will fit on our cars? I have a hole in my outer CV boot on the drivers side and it needs replaced, dealership wont replace it under warranty so I would much rather just do it myself. I can buy one for my car from the dealership but its like 50 bucks. I'm just trying to find an alternative. Thanks in advance.
EDIT: Anybody know how to replace a CV boot? I mean I'm sure I could figure it out but its so much easier to ask for help.
Old Dec 5, 2007 | 01:02 PM
D4u2s0t's Avatar
dude, if it's 50 dollars just buy it. if it was hundreds i can see you looking to cut corners a little bit, but for 50 bucks not worth the risk
Old Dec 5, 2007 | 01:05 PM
YelloEye's Avatar
Reason I was asking is because replacement kits for cavys and other cars is only like 10 bucks. But if there is no alternative I guess I will have to talk to the $tealership.
Old Dec 5, 2007 | 04:14 PM
MTPockets's Avatar
Boot replacement would require removal of the brake caliper, remove rotor, remove axle nut, free up the steering knuckle by unbolting the lower strut mounts, tie rod ends and stabilizer bar end links. Drop the knuckle off the splined end of the CV shaft, provide support for the CV shaft so it doesn't slide out of the trans case and support the knuckle and caliper so you don't break any hoses and wires off. Remove worn boot, totally clean the effected CV joint(s), regrease, slide the new boot(s) over the shaft, reclamp, reverse the steps. It's one of those jobs I'll gladly pay a reputable independent shop $200 to do for me!
Old Dec 5, 2007 | 04:30 PM
YelloEye's Avatar
lol greaaat
Old Dec 5, 2007 | 04:32 PM
XM15's Avatar
Doesn't sound too hard though, just time consuming. Bite the bullet and make a day of it!
bgbearcatfan's Avatar
If that is not an exaggeration (i have no clue how to myself), that sucks lol
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
