does anyone else have a noisy supercharger belt tensioner assembly?
Old Aug 1, 2012 | 12:39 AM
Shogokuma's Avatar
driving me nuts, the funny thing is that its a bit quietter since i replaced my timing chain tensionner... but still intermitten almos always noisy on startup. grinding type noise almost sounds like a loose heat sheild
Old Aug 1, 2012 | 12:42 AM
Twoozofjuice's Avatar
yeah mines noisy as hell. its ridiculous. it goes away once the car is hot which is weird? lol
Old Aug 1, 2012 | 12:44 AM
Shogokuma's Avatar
wierd right? i wonder if its related to timing? like i can see the belt jump a bit
Old Aug 1, 2012 | 12:46 AM
EXsoccer1921's Avatar
nope. went turbo
Old Aug 1, 2012 | 12:50 AM
nope. went turbo
i dream of not having a noisy tensioner and burning out in your godcar lmao.
that also seems the best way to get rid of the noisy tensioner...im thinking its because the belts too big but i dont wanna go a smaller pulley and put on the stage 2 belt i have because i think ill blow my car up like that.
Old Aug 2, 2012 | 12:40 PM
Shogokuma's Avatar
so whats the cure a brand new tensionner assembly?
Old Aug 2, 2012 | 12:56 PM
i had to replace the assembly, it was squeaking/grinding too much.
i must say.. it was kinda of a pain in the ass. the bottom bolt u gotta undo is inbetween the wheel well and u only got like an inch of room to play with. so i couldn't fit a socket in there had to turn it like 20 degrees at a time with a wrench... so if ur gonna do this, anyone, i would recommend getting a socket wrench for the job. sorry don't know the size. peace
Old Aug 2, 2012 | 03:55 PM
Shogokuma's Avatar
if you tell me its completely solve the grinding noise then ill do it because i took it apart in hopes to quiet it down with silicone and it did for 3 weeks...
Old Aug 2, 2012 | 03:57 PM
i was trying the silicone method for a while too man, i even tried to just replace the pulley but that just didn't do it
Old Aug 2, 2012 | 04:47 PM
i think its 5/8 if i remember correctly. I found the perfect size wrench for it and btw dont let the damn socket fall in the small gap in between the wheel well and the engine bay.
my tensioner was fine before i went sc then when i went sc i broke my stock one and got a used one from the junkyard so not sure if thats why mine is noisy. Im hoping later on to get a adjustable tensioner from zzp
Old Aug 3, 2012 | 06:48 PM
Shogokuma's Avatar
my theory is the cylinder is weaker than when it was new causing the belt to slip/jump...
Old Sep 6, 2012 | 10:51 PM
Shogokuma's Avatar
update i have the timing chain and timing chian guide replaced and my belt tentioner is quiet on any kind of startup. so in some way it is related to the timing of the car
Old Sep 6, 2012 | 10:59 PM
brian.olsson's Avatar
Just replace the tensioner pulley, their like 15 bucks at the auto parts store, with new bearings, and takes about five mins to swap, yeah, their sealed, but dirt and stuff from the belt still get in the bearing and cause it to make noise
Old Sep 7, 2012 | 12:03 AM
Shogokuma's Avatar
already did that, it didnt cure it, i had to replace the complete chain guide and timing chain and timimn chain tentioner
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
