Doing a new intake manifold gasket..have some questions
Main thing I'm concerned with is it still leaking..Do most of you all use rtv on the new gasket and where would I put it?
I didn't use RTV on mine and didn't have any leaks. Make sure the mating surfaces are clean, you might have to use very fine sandpaper to clean up the surfaces. When tightening the manifold onto the head, hand tighten the bolts from the center working your way outward equally left and right, then torque them in the same pattern.
If u want to know if it's leaking , let ur car idle, spray some ether , or engine starting fluid around the Mani where it bolts to head, if ur engine sputters ur leaking if not ur good
