Doing a new intake manifold gasket..have some questions
Old Aug 8, 2015 | 01:51 PM
volsfan92's Avatar
Question Doing a new intake manifold gasket..have some questions
Main thing I'm concerned with is it still leaking..Do most of you all use rtv on the new gasket and where would I put it?
Old Aug 8, 2015 | 02:07 PM
LsCobalt07's Avatar
I didn't use RTV on mine and didn't have any leaks. Make sure the mating surfaces are clean, you might have to use very fine sandpaper to clean up the surfaces. When tightening the manifold onto the head, hand tighten the bolts from the center working your way outward equally left and right, then torque them in the same pattern.
Old Aug 8, 2015 | 11:11 PM
Use a blue sos pad not sandpaper. You want to remove foreign material on the aluminum not the aluminum
Old Aug 10, 2015 | 05:40 PM
tomj77's Avatar
If u want to know if it's leaking , let ur car idle, spray some ether , or engine starting fluid around the Mani where it bolts to head, if ur engine sputters ur leaking if not ur good
Old Aug 10, 2015 | 06:35 PM
double clutch's Avatar
You dont have to use rtv but you can. Definitely hit it with a scuff pad or something to get the old gasket material off
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
