Downshifting stalling issues
Old Jun 19, 2013 | 11:16 AM
degeorgee1's Avatar
Sometimes when I downshift from 2nd into 1st my car will stall out. It is an intermittent issue. The car idles just under 1000 rpms usually but when I stop it will go down to 500 then spike up to 1500 and back down and stall out. Has anyone else had this issue or know what could be causing it? I scanned the engine and the code popped up saying "camshaft position sensor failure"
Old Jun 19, 2013 | 11:54 AM
Bluelightning's Avatar
Got Bewst?
Change your camshaft position sensor. Just a stab in the dark.
Old Jun 19, 2013 | 11:55 AM
mrbelvedere's Avatar
lmaorotf
Old Jun 19, 2013 | 12:07 PM
tamadrummer's Avatar
Does it only happen when you downshift from 2nd to 1st? Or will it happen even if you let it idle, for example, at a stop light? Might be a vacuum leak if it's surging like that. Just a guess.
Old Jun 19, 2013 | 12:12 PM
andrewcarr1993's Avatar
Clean the TB.
Old Jun 19, 2013 | 01:01 PM
Clean the TB.
see the main problem yet
O.P. post your problems here next time not in the performance section
https://www.cobaltss.net/forums/prob...aintenance-69/
Old Jun 19, 2013 | 05:29 PM
degeorgee1's Avatar
It won't happen in neutral idling just if I downshift from 2nd to first and stop or stop in second with the clutch held in (tried it out just to see)
Old Jun 19, 2013 | 05:34 PM
BPacak's Avatar
Vtec Rep
Why would you downshift into 1st
Old Jun 19, 2013 | 06:12 PM
He feels like getting whiplash?
Old Jun 20, 2013 | 02:08 PM
Cman46290's Avatar
yeah why would you ever downshift into first gear unless you are like in stop and go traffic....?
That aside.... i agree... my car did this when i bought it as well.... clean out the throttle body.... i havent had it happen since i cleaneed mine.
Dont spray cleaner right into it though... spray a towel with throttle body cleaner or brake cleaner and wipe it down really good inside.... and around rim the throttle plate itself.
Old Jul 14, 2013 | 11:02 PM
degeorgee1's Avatar
Update!
Cleaned out the throttle body and she is running 100% perfect! Thanks everyone.
Update!
Update!
Cleaned out the throttle body and she is running 100% perfect! Thanks everyone!
Update!
Problem solved. Cleaned out the throttle body and my car runs great. Thanks to all that helped!
Last edited by degeorgee1; Jul 14, 2013 at 11:02 PM. Reason: Automerged Doublepost
turbochargedss2012
Sep 20, 2023 12:17 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
