Drivetrain moving around. help!
So I have been noticing an issue which keeps getting worse and worse - I am getting what feels like (and occasionally sounds like) drivetrain movement when backing up down a camberd driveway that meets another opposing hill at 45* (clunking) and then a more discreet feeling of movement when on/off the power and inaccuracy shifting. I feel like when autocrossing it has moved enough to pull the car out of gear! I just unbolted the mounts from the trans to see how they felt and both seem fine. I ordered a new rear mount because someone said theirs discentegrated and the sound seems to be coming from that side, but the old one seems to be just as stiff when I unbolt ot from the trans and move it around. The car does have 100k on it, but I auto-x a lot and don't need stuff breaking. I plan on running prothane everythang bushing wise, but want to fix this problem before I throw parts at the car. Ideas?
As an example, when I let off the power on the highway I can literally feel theengine/trans unload and shift fore/aft in a rocking motion. It is driving me batsh*t
Its an LNF. I'm wondering if it is the upper trans mount...
I saw some info on someone filling it (its under the fusebox apparently).
Could this be a transmission issue?
CABS?
I'm very frustrated, I'm going to fix this - ASAP.
CABS?
You on stock mounts? The stock tranny mounts are ridiculously soft. I threw on zzp tranny mounts and jt made it feel 100 times better. Don't Boyer butting another stock one on.
And if you have 100k and auto x a lot your cabs are probably toast. Grab some Powell cabs.
It's the mounts being soft, contact Powell for his stage 1 mounts and ced for a new stock rear mount. My did that with worn ottp mounts replaced with Powells and stock, now it's gone
Sl0wbaltSS
Nov 21, 2018 11:11 PM
