Drivetrain Problem!! Unusual Noises
Old Sep 14, 2012 | 07:30 AM
CudaJoe's Avatar
Okay hello everyone,
You may have recalled that I thought my turbo was going because I heard some strange noises but I later corrected myself and said the transmission was becoming a little louder.
Well guess what, its pretty damn loud now and coming from the front left wheel!!! I checked the rotor and break thinking something is scraping across the rotor every now and then but they look fine ?!?!!?
The noise is intermittent and only occurs when im rolling with my foot off the gas at any speed. The intermittent noise gets faster as I go faster. When I accelerate the noise dissappears. Very strange. I just rotated my wheels too after cleaning them spick and span. I have my ideas as too what it is but I want to see what you guys think?
The noise sounds like a squeeky bed spring... or maybe a thick metal wire dragging across a slotted rotor I guess? Again Rotors look normal front and back, nothing is dragging. I can almost FEEL something through the steerwheel as the noise occurs.
Old Sep 14, 2012 | 07:34 AM
CudaJoe's Avatar
This is what i suspect...
Pretty sure you guys will think the same.
How to Find a Bad Wheel Bearing - EricTheCarGuy - YouTube
Old Sep 14, 2012 | 08:13 AM
Joe Schulte's Avatar
My brand new trans makes noises in low gear's lugging around quite often, was stuck in a construction zone against a concrete barrier and it was quite loud, like loose **** inside. Exciting.
Old Sep 14, 2012 | 08:30 AM
CudaJoe's Avatar
This is all gears. If I throw the clutch in, the noise is still there. If I use the brakes, the noise quites down a bit. Its wierd. Thats why I thought it might be the brakes at first.
Old Sep 14, 2012 | 12:44 PM
CudaJoe's Avatar
PROBLEM SOLVED....
I CARE NOT TO DESCRIBE WHAT THE PROBLEM WAS BUT I BET EVERYONE ELSE THAT HEARS THIS SAME ISSUE PROBABLY HAS THE SAME THING AS ME...
lol. I cant believe I did this.
Old Sep 14, 2012 | 04:53 PM
bluebalt07's Avatar
You can't just ask for help with an issue and then not tell everyone how you solved it lol what'd you do leave a bolt out of the brakes or forget a lug? lol
Old Sep 14, 2012 | 06:50 PM
CudaJoe's Avatar
Forgot to tighten all lug nuts on the driver side front wheel. One was so lose i could take it off with my hand in two turns
Old Sep 14, 2012 | 07:09 PM
Silv3r's Avatar
/facepalm
lol
Old Sep 15, 2012 | 01:03 AM
bluebalt07's Avatar
Hey at least you caught it before something got damaged. Everyone makes mistake sometimes. Plus if you're clever, you could say that you did this the same day as eating your special bag of cheetos and that they altered your ability for quality work
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Bohb
Sep 27, 2015 09:11 PM
