DTC code
Old Aug 30, 2010 | 05:20 PM
wheels's Avatar
Canada DTC code
PO335B code ? ..... revved the car pretty hard and , then had no tach....no power...it would boost but no power ....alot of back firing...then shut it off...waited a few mins or so...started it up again...ran fine ever since.... and if its the crank sensor...is a relearn totally nessesary? some say yes ...some say no ? thanks in advance,
Ray
Old Aug 30, 2010 | 08:07 PM
army_greywolf's Avatar
the answer is yes.
Old Aug 30, 2010 | 09:28 PM
wheels's Avatar
Originally Posted by army_greywolf
the answer is yes.
how exactly is this performed? what needs to be done
Old Aug 30, 2010 | 09:58 PM
Pyros777's Avatar
Its a simple procedure but you need access to a Tech II or HP Tuners.
With HP Tuners all you have to do is click "Perform CASE relearn" and it guides you through the process.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
