Electrical issues? = no boost
Old 02-26-2015, 03:30 PM
06victoryred's Avatar
Thumbs down Electrical issues? = no boost
I have been having no boost for about two weeks now. The gauge cycles through the vacuum section like normal and then all of a sudden under acceleration it gets to zero or -1 and it stops on a dime.
After some research I swapped the bypass solenoid and the problem remained. Someone suggested the EVAP solenoid based upon the CEL codes I was popping up. So that was swapped and no better.
I ran the boost bypass mod for a ride around the neighborhood and the boost was back but only to about 6-7 psi, so I'm assuming its not the actual bypass actuator.
The codes that keep popping up since replacing the two solenoids are:
P0033 Supercharger Bypass Valve Solenoid Control Circuit -PCM (saying its confirmed open)
P0171 Fuel Trim System Lean -PCM (in bank 1)
P0101 Mass Air Flow (MAF) Sensor Performance - PCM (saying its pending).
Anyone with a guess or some other troubleshooting ideas would be great.
Thanks.
Old 02-27-2015, 05:53 PM
bump?
anything is helpful
Old 03-02-2015, 11:23 AM
So I figured out the MAF issues. Had a hole worn into the CAI. Still need help with the P0033 code if anyone has any guesses.
05-28-2022 03:47 AM
Solaris99
28
03-15-2017 01:22 PM
ernnyyes
10-02-2015 05:16 PM
Trav3480
10-01-2015 08:17 PM
Tupp
09-30-2015 08:18 PM
Quick Reply: Electrical issues? = no boost
