Electrical Issues.
Old Feb 21, 2011 | 02:47 PM
elite_Cyborg's Avatar
Electrical Issues.
Soo the car won't start.
Throws App sensor code, a Throttle position high and low voltage code, The IC pump stays on all the time whether the key is in the ignition or not, and the fuel pump relay doesn't turn on when the key is turned on.
Its not the fuel pump relay itself/ Its not the ignition switch and i checked all the grounds.
Somehow my pcm is getting constant ignition power, the IC pump shuts of if shut off in hpt. the fuel pump is still not turning on, where could the short be between the vcm and the ignition signal?
[PCM] P0230 - Fuel Pump Relay Control Circuit (SES) (Pending) (History) (Current) (Immature)
[PCM] P0443 - EVAP Purge Solenoid Valve 1 Control CKT (Pending) (Old) (Current) (Immature)
[PCM] P2101 - Throttle Actuator Control Motor Circuit Range/Performance (SES) (Pending) (History) (Current) (Immature)
[PCM] P1682 - Driver 5 Line 2 (Pending) (History) (Current) (Immature)
[PCM] P2610 - ECM/PCM Internal Engine Off Timer Performance (SES) (Pending) (Old) (History) (Current) (Immature)
Old Feb 21, 2011 | 03:03 PM
Im getting so pissed, lol
Old Feb 21, 2011 | 10:50 PM
Bumjpsffjosidj
Old Feb 21, 2011 | 11:44 PM
5hizn1t's Avatar
Here's a copy/paste of what is on SI about the P2610:
P2610
• The ECM is powered down.
• The intake air temperature is between -40 to +125°C (-40 to +257°F).
• DTC P2610 runs once per ignition cycle.
Conditions for Setting the DTCs
The ECM detects an internal failure or incomplete programming for more than 10 seconds.
Mentioning what kind of car you have might help people try and help you.
Old Feb 22, 2011 | 12:02 AM
07 lsj
Old Feb 22, 2011 | 02:51 PM
Coblasts's Avatar
If youve been tuning it I would try reloading a know good tune,maybe the pcm is corupted and reloading may fix it.
Another thing is to check the pcm connectors,could be loose.
Pull and reseat all relays in the fuse box,concentrate on the crank,start relays could be loose due to whell hop
Etc.
Old Feb 22, 2011 | 03:18 PM
Did all this before posting. Can't seem to figure out the issue
Old Feb 22, 2011 | 03:38 PM
Coblasts's Avatar
What were you doing before it didnt start.?
Old Feb 22, 2011 | 04:27 PM
putting a new motor in
Old Feb 22, 2011 | 04:40 PM
Coblasts's Avatar
Did you put the motor in with the harnesses installed,possile pinched wire,
Take a good look at the harnesses where they come out of the fire wall for any mark indicating that
It might of been squished.
Then take the harness apart to take a good look.
Old Feb 22, 2011 | 07:23 PM
are there any sensor differences between the years. ie canbus and voltage?
Old Apr 8, 2011 | 11:52 PM
slickss24's Avatar
i had the same problem when i put a new motor in mine i had the throttle body sensor and coil sensor switched they are the same color plug and are on the same harness i spent a week trying to figure it out but switched the two and it started right up
Old Dec 18, 2011 | 06:51 PM
el_angelito's Avatar
do you found the problem because I just take my supercharger off and transmission to upgrade somethings and after I install everything my car start but after a time with out warning it goes off and doesnt start again.
Old Dec 18, 2011 | 06:55 PM
Powell Race Parts's Avatar
make sure the throttle body connector is properly installed el angelito. for the OP I would suggest removing the fuse box and checking the connectors. Also, making sure all the correct connectors are made, the coil paks and the cps are interchangeable. The PCM pins are an issue as well, they can wear out at the connector so be cautious.
Old Jan 23, 2012 | 08:26 PM
I check all the wires and i have a intermittent problem and is with the fuel
Old Jan 23, 2012 | 08:46 PM
getwicked's Avatar
See if you can find a new fuse block to throw in for testing.. Sometimes they have internal faults. Big problem in the Impala's but have seen a few in HHR/Cobalt
Old Jan 26, 2012 | 08:32 PM
getwicked's Avatar
Also: make sure you put all the relays and fuses back it the right positions.
Solaris99
28
Mar 15, 2017 01:22 PM
ernnyyes
Oct 2, 2015 05:16 PM
yellow dragon
Sep 28, 2015 09:49 PM
jcarroll53
Sep 24, 2015 07:43 PM
